Home » Language IDEs » Java Development Tools (JDT) » Fixing a compile error requires closing an unrelated project
Fixing a compile error requires closing an unrelated project [message #526772] Mon, 12 April 2010 17:00 Go to next message
I'm seeing a very odd problem with project references on the Java Build Path.
I have four somewhat related projects (among others). They are really just two projects, but two copies of each checked out from a specific SVN branch. Project "foo" has a project reference to "bar" in the Java Build Path. Project "fooX" has a project reference to "barX" in the Java Build Path. There are changes in "fooX" and "barX" that are related, such that "foo" and "bar" work together, and "fooX" and "barX" should work together, but "fooX" cannot work with "bar".
I have no compile errors in "foo", "bar", or "barX". There are several compile errors in "fooX" that make no sense at all. The errors occur on lines that are referencing methods in "barX", but the errors make it seem like it's actually referencing "bar" instead. In fact, when I click on the method call with the red underline and do "open declaration", it opens the file in the "bar" project, not "barX".
Even stranger, what I can do to work around this problem is to temporarily close project "bar". As soon as I close it, project "fooX" recompiles and the errors go away. When I go to the line that had the compile error and do "open declaration" again, it goes to the correct class in the "barX" project.
I will file a ticket for this in a few minutes, but I doubt I'll be able to build a repeatable test case for this outside of my environment.
Re: Fixing a compile error requires closing an unrelated project [message #526800 is a reply to message #526772] Mon, 12 April 2010 20:26 Go to previous messageGo to next message
> Path.
Check your output locations for the projects. If bar and barX share the
same output location, then one projects class files would over write the
class files of the other project.
Re: Fixing a compile error requires closing an unrelated project [message #526802 is a reply to message #526800] Mon, 12 April 2010 20:47 Go to previous message
Good idea, but that's not it. Each project's "output folder" is the "bin" directory in the root of each project. None of these projects share an output folder.
Previous Topic:Help with tomcat and new project on buildpath.
Next Topic:Eclipse IDE Environment
Current Time: Sun Jul 20 11:02:56 EDT 2025
Powered by FUDForum. Page generated in 0.04915 seconds
