XMI Deserialization problem [message #526799] |
Mon, 12 April 2010 20:32  |
I have a problem with XMI deserialization. I have two programs and they are passing EMF objects
back and forth using XMI. First, the sending application (1) creates an XMIResource in Resource Set
1 and adds Object A to it and send it to the receiving application (2). The receiving application
(2) recreates Object A in a Resource in Resource Set 2. Now the sending application(1) creates a
new XMIResource in ResourceSet1 and creates Object B which has a non-containment reference to Object
A. It then sends Object B (using its Resource) to the receiving application(2). The receiving
application(2) creates a new Resource in ResourceSet2 and has that resource read the XMI in to
create Object B. However it fails with this:
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '1'.
( dbo://localhost/junit/storage/JUNIT/MODEL/4d90ff32-a700-47bb -a1d7-5f371bf86536, 2, 398)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleForwardRefer ences(XMLHandler.java:1154)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.endDocument(XMLHan dler.java:1228)
at org.apache.xerces.parsers.AbstractSAXParser.endDocument(Unkn own Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl.endEntity(Unkn own Source)
at org.apache.xerces.impl.XMLEntityManager.endEntity(Unknown Source)
at org.apache.xerces.impl.XMLEntityScanner.load(Unknown Source)
at org.apache.xerces.impl.XMLEntityScanner.skipSpaces(Unknown Source)
at org.apache.xerces.impl.XMLDocumentScannerImpl$TrailingMiscDi spatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unk nown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
... 71 more
The reference is correct (I believe) as the Object A is at URI/1 and Object B is at
URI/4d90ff32-a700-47bb-a1d7-5f371bf86536 in both resource sets. It looks like the XMLHandler is
only looking in Object B's resource for Object A, when it should either create a proxy or look in
Object B's resource set.
The URIs for the mirroring resources end the same way on both sides, but start very differently
(different schemes and different paths up until the last 2-3 segments).
Am I missing something here? I've been able to pass cross-document proxies in the past.
Thanks in advance!
Sincerely,
Stephen McCants
Re: XMI Deserialization problem [message #526951 is a reply to message #526799] |
Tue, 13 April 2010 10:50   |
Stephen,
Comments below.
Stephen McCants wrote:
> Hello,
> and they are passing EMF objects back and forth using XMI. First, the
> sending application (1) creates an XMIResource in Resource Set 1 and
> receiving application (2) recreates Object A in a Resource in Resource
> Set 2. Now the sending application(1) creates a new XMIResource in
> reference to Object A. It then sends Object B (using its Resource) to
> the receiving application(2). The receiving application(2) creates a
> reference '1'.
> 2, 398)
> at
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> ... 71 more
This looks like the handling of a same document reference, not a cross
resource reference.
> Object B is at URI/4d90ff32-a700-47bb-a1d7-5f371bf86536 in both
> resource sets. It looks like the XMLHandler is only looking in Object
Indeed.
> when it should either create a proxy or look in Object B's resource set.
That depends on the form of the URI. What does it actually look like?
> sides, but start very differently (different schemes and different
So as long as the paths are relatively correct it should be fine, but it
really looks like a same document reference and that really is only
produced if the objects are in the same resource when they're serialized.
Check carefully before you serialize B what A's eResource() method
returns...
> Thanks in advance!
> Sincerely,
> Stephen McCants
Re: XMI Deserialization problem [message #526985 is a reply to message #526951] |
Tue, 13 April 2010 11:49  |
Hi Ed,
Thanks for your help. You put me on the right track and I found and solved the problem in my code.
Thanks!
--Stephen
Ed Merks wrote:
> Stephen,
> Comments below.
>> Hello,
>> reference '1'.
>> 2, 398)
>> at
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> ... 71 more
> resource reference.
> Indeed.
> returns...
>> Thanks in advance!
>> Sincerely,
>> Stephen McCants
FUDForum. Page generated in 0.06297 seconds
