Loading an EMFCompare differences model [message #526672] |
Mon, 12 April 2010 10:53  |
Hi. After comparing 2 versions of a model, I get the differences model and save it as an XMI file. Now I want to load this model to navigate it using EMF API, but I'm getting this error:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/emf/compare/diff/1.1' not found. (file:/C:/eclipseGalileo/workspace/org.eclipse.emf.examples. library/model/result2.xmi, 2, 296)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
So basically it says that diff metamodel can't be found. Do I need to have a diff metamodel instance in the workspace for being able to do what I want to do? If this is the case, where can I get this resources?
Thanks in advance.
Sebastián.
Re: Loading an EMFCompare differences model [message #526702 is a reply to message #526672] |
Mon, 12 April 2010 12:13   |
Originally posted by: formatzeh.gmx.de
Hi Sebasián,
I assume that you are running your code outside of Eclipse? In such a
case you have to register the used packages manually because the Eclipse
registry isn't present. Try this:
EPackage.Registry.INSTANCE.put(DiffPackage.eNS_URI, DiffPackage.eINSTANCE);
best regards,
Gilbert
Am 12.04.2010 16:53, schrieb jsebas85@gmail.com:
> Thanks in advance.
> Sebastián.
Re: Loading an EMFCompare differences model [message #526897 is a reply to message #526726] |
Tue, 13 April 2010 08:32   |
--------------010907050506090407030906
Hi Sebastián, Gilbert,
The line of code Gilbert pointed out is exactly what you need if you are
not using the default eclipse actions to load this model (ie, you create
the resource on the emfdiff path and then use EMF APIs to load it
instead of double clicking the emfdiff file in the workspace).
You'll need to add Gilbert's code _before_ creating and loading the EMF
resource.
However if you are using standard Eclipse actions to load the model
(double click in the workspace comes in mind), then what you encounter
is a bug.
Could you tell us which of these cases you're in?
Laurent Goubet
Obeo
Gilbert Mirenque wrote:
> Hi Sebastián,
>> Actually, I'm running the code inside Eclipse, so it is not the case.
>> Probably I would also have to register diff metamodel, but as I don't
>> have a metamodel instance (an .ecore file in my workspace) I don't know
>> how to do it.
> Then the code line from my previous answer should do the trick anyway.
> If the code doesn't compile then you need to add a dependency to the
> org.eclipse.emf.compare.diff plugin.
> best regards,
> Gilbert
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010907050506090407030906--
Re: Loading an EMFCompare differences model [message #622464 is a reply to message #526726] |
resource.
is a bug.
Laurent Goubet
Obeo
> Hi Sebastián,
>> how to do it.
> best regards,
> Gilbert
Re: Loading an EMFCompare differences model [message #622465 is a reply to message #526897] |
Tue, 13 April 2010 11:02  |
Thanks to both of you for your help. For obtaining the differences model, I was using standard Eclipse actions, so I thought metamodels were already registered.
So what I had to do was to include 3 dependencies in the plugin.xml
org.eclipse.emf.compare.match
And add 2 lines of code before loading the resources:
EPackage.Registry.INSTANCE.put(MatchPackage.eNS_URI, MatchPackage.eINSTANCE);
Thanks again :)
FUDForum. Page generated in 0.06939 seconds
