Home » Modeling » GMF (Graphical Modeling Framework) » How to use attributes of referenced objects as labels
How to use attributes of referenced objects as labels [message #526548] Mon, 12 April 2010 04:41 Go to next message
Originally posted by: mikekilo.gmx.de
Hey friends,
i am new to gmf and have a problem i could neither solve with the
newsgroup archive nor with the power of google.
Lets expect that there are two classes A and B.
B has an attribute called "name". A has a reference to one object of B.
What i want (in the graphical editor) is a label on object/node a, where
the user is able to see/set the name of the referenced object b.Maybe
one of you can give me a hint what part i missed in the gmfgraph or
gmfmap file.
Many thanks in advance for your help.
Matthias
Re: How to use attributes of referenced objects as labels [message #526582 is a reply to message #526548] Mon, 12 April 2010 07:02 Go to previous messageGo to next message
Hello Matthias,
One simple way would be to create a Compartment for the referenced element
and display only the name in a no-border-rectangle in a node.
An other way would be to introduce a derived property in your model and
calculate the value from the child object. You need to notify adapters on
reference changes. @see
http://wiki.eclipse.org/EMF/Recipes#Recipe:_Derived_Attribut e_Notifier
A third way would be to change the generated GMF code.
Enrico
"Matthias Kloppenborg" <mikekilo@gmx.de> schrieb im Newsbeitrag
news:hpumdm$l7q$1@build.eclipse.org...
> Hey friends,
> gmfmap file.
> Matthias
Re: How to use attributes of referenced objects as labels [message #526592 is a reply to message #526582] Mon, 12 April 2010 07:37 Go to previous message
Hello Enrico,
thanks for your help. I think i will try the first solution. Can you
provide me with more resources about compartments?
I read several GMF Tutorials, but I dont feel comfortable with the
informations which are given there. Need more input. ;)
Matthias
Previous Topic:"A handler conflict occurred.  This may disable some commands."
Next Topic:IP Dok
Current Time: Sat Jul 19 22:41:47 EDT 2025
Powered by FUDForum. Page generated in 0.03955 seconds
