Home » Modeling » M2T (model-to-text transformation) » Java Extension(does not return anything)
Java Extension [message #526568] Mon, 12 April 2010 06:14 Go to next message
I want to call a JAVA method from my Xtend file.
In my Xpand file, it's called like this :
package «package(this.name)»;
In Xtend, I defined this extension :
Void package (String s) :
JAVA specific.Package.Name(java.lang.String);
And my JAVA file is that :
package specific;
public class Package {
public final static void Name(String name){
System.out.println("mypackage"+name);
But when I run the workflow, I get
package ;
What do I need to modify ?
[Updated on: Mon, 12 April 2010 06:14] by Moderator
Re: Java Extension [message #526571 is a reply to message #526568] Mon, 12 April 2010 06:29 Go to previous messageGo to next message
hi,
package ;
is actually that what you tell the gerneator to produce in your template
package <<nothing>>; => package ;
what is your expected result?
Re: Java Extension [message #526577 is a reply to message #526568] Mon, 12 April 2010 06:40 Go to previous messageGo to next message
Hi again,
if you want to let the java extension calculate your package name your should modify your code like this
String package (String s) :
package specific;
public final static String Name(String name){
 return "mypackage"+name;
Re: Java Extension [message #526586 is a reply to message #526568] Mon, 12 April 2010 07:23 Go to previous messageGo to next message
Hello Maxime,
thank you very much for your question. This feature is not good described in the Xpand documentation. I will update this part of the documentation.
Please try:
return ("mypackage"+name);
You have forgot to specify the return.
The System.out.println inside the documentation is for logging to the console but does no generator output.
Darius
Re: Java Extension [message #526588 is a reply to message #526568] Mon, 12 April 2010 07:25 Go to previous message
expected resultat was
package mypackageName;
Your solution is indeed working, thank you.
Previous Topic:[XPand][AOP][Sculptor] problem calling the metamodel
Next Topic:Defining package from workflow
Current Time: Sat Jul 19 11:58:10 EDT 2025
Powered by FUDForum. Page generated in 0.03944 seconds
