Home » Eclipse Projects » Rich Client Platform (RCP) » [solved] Common Navigator Drag and Drop(I want to drag a custom Object to a GEF EditPart)
icon14.gif  [solved] Common Navigator Drag and Drop [message #526030] Thu, 08 April 2010 10:50 Go to next message
I want to drag a Node Object from my Common Navigator onto an EditPart.
It already works with a Palette of the GEF Editor.
My Node is as simle as it can be:
class Node {
    private String name;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
After googling and trying around for a day I am very confused about which steps to take in order to get the drag started with the correct Transfer Class and dragAssistant.
How do I accomplish a proper drag from the CN? Drop should work for it does with the Palette already.
Thanks for your help in advance.
Chris
[Updated on: Mon, 12 April 2010 05:35] by Moderator
Re: Common Navigator Drag and Drop [message #526184 is a reply to message #526030] Fri, 09 April 2010 03:43 Go to previous messageGo to next message
Look at the org.eclipse.ui.navigator.viewer extension point and the dragAssistant description. You may not need a dragAssistant because it uses the LocalSelectionTransfer mechanism on the drag to capture your object.
Re: Common Navigator Drag and Drop [message #526528 is a reply to message #526184] Mon, 12 April 2010 04:00 Go to previous messageGo to next message
Thank you for pointing me into the correct dirction - the drag works fine.
The issue is the drop listener I am using on the EditPart. It uses the TemplateTransferDropTargetListener which did not accept the drag apparently.
Now I have to figure out to use Palette dnd and CN dnd at the same time.
Re: Common Navigator Drag and Drop [message #526551 is a reply to message #526528] Mon, 12 April 2010 05:27 Go to previous message
Quick follow up.
I figured out how to solve my problem very painlessly:
by using the TemplateTransfer one can use the CN Nodes just like the GEF Palette.
  1. create a DragAdapterAssistant extending CommonDragAdapterAssistant
  2. as Transfer use the org.eclipse.gef.dnd.TemplateTransfer
  3. to transfer the data (template) use TemplateTransfer.getInstance().setTemplate(data)
  4. in plugin.xml add a dragAssistant to org.eclipse.ui.navigator.viewer and configure it with your viewerID and the new DragAdapterAssistant class
That is it.
Previous Topic:How do I find out the style of an SWT part?
Next Topic:Adding a file menu item via an extension point
Current Time: Sat Jul 19 12:59:52 EDT 2025
Powered by FUDForum. Page generated in 0.06767 seconds
