Home » Eclipse Projects » Mylyn » [wikitext] Converting mbedded images
[wikitext] Converting mbedded images [message #503798] Tue, 15 December 2009 15:05 Go to next message
I'd like to have images appear inline in wikitext-to-eclipse-help as opposed to as href links. Is there any OOTB functionality for this, or do I need to write some kind of custom converter?
cheers,
Miles
Re: [wikitext] Converting mbedded images [message #503843 is a reply to message #503798] Tue, 15 December 2009 18:53 Go to previous messageGo to next message
One other question..on my setup using ant task, > and < are not being converted. Is this suported for mediawiki wikitext to eclipse help?
Re: [wikitext] Converting mbedded images [message #506315 is a reply to message #503798] Wed, 06 January 2010 18:19 Go to previous messageGo to next message
Miles Parker wrote:
> cheers,
> Miles
Miles,
Can you give more details? I'm not sure which images you're referring to, what markup language you're using, etc.
Perhaps you could provide a fragment of markup and paste the HTML you're generating, along with what you'd like to see.
Re: [wikitext] Converting mbedded images [message #506316 is a reply to message #503843] Wed, 06 January 2010 18:19 Go to previous messageGo to next message
What do you mean by not being converted? Please file a bug if you think that there's a problem.
Re: [wikitext] Converting mbedded images [message #525815 is a reply to message #506316] Wed, 07 April 2010 17:06 Go to previous messageGo to next message
David Green wrote on Wed, 06 January 2010 18:19
Following up on this finally.. basically I just want to find out what the formula is for specifying an embedded image in wikitext (mediawiki) such that it appears correctly in the generated Eclipse html docs. I'm currently doing docs locally, so it won't be using the auto wiki [[image:]] upload strategy. There might simply not be a way to do this as a limitation of mediawiki, not wikitext, but I'm hoping for some kind of solution that avoids actually having to manually edit the html post conversion.
thanks,
Miles
Re: [wikitext] Converting mbedded images [message #525819 is a reply to message #503798] Wed, 07 April 2010 17:15 Go to previous messageGo to next message
Actually, let me answer my own question. After experimenting more, the extended form of the link syntax does work:
[[Image:myrelpath/MyImage.png]]
gets:
<img border="0" src="myrelpath/MyImage.png" />
Just as it should. I think I was just doing something dumb..didn't realize that mediawiki was case sensitive..
Re: [wikitext] Converting mbedded images [message #544801 is a reply to message #503798] Mon, 05 July 2010 10:40 Go to previous messageGo to next message
Am experiencing problems with the downloading of images from our Mediawiki site. Rest of page converts fine but images are not downloaded into the doc project. Tried using variations of image links as described above but then the images don't appear in the wiki page as they should.
Looked at the Egit online doc example and they use the standard [[Image:file_name]] syntax when referring to images.
Has to be something simple I am missing, but can't figure out what it might be. Any suggestions?
Thx // frank
Re: [wikitext] Converting mbedded images [message #544856 is a reply to message #544801] Mon, 05 July 2010 13:47 Go to previous message
L. Frank Turovich wrote on Mon, 05 July 2010 10:40
Hi Frank,
That's the format I'm using as well i.e.:
[[Image:images/edit_tutorial/SimpleTutorial3CreateModel.png] ]
Note that the image references are relative to the doc location, not the project root.
Re: [wikitext] Converting mbedded images [message #601017 is a reply to message #506316] Wed, 07 April 2010 17:06 Go to previous message
thanks,
Miles
Previous Topic:File history in Mylyn
Next Topic:My tasks don't display Planning Tab. I see only the private tab and have no Priority combo-box.
Current Time: Sat Jul 19 21:53:22 EDT 2025
Powered by FUDForum. Page generated in 0.25353 seconds
