Home » Eclipse Projects » JFace » Widget transparency
Widget transparency [message #525480] Tue, 06 April 2010 12:53 Go to next message
Does eclipse support transparency for SWT and JFace? I am especially interested in making a small transparent window with transparent buttons that can be popped up over my existing application (which is an RCP app).
If I need to post this in other forums please let me know.
Thanks.
Re: Widget transparency [message #525714 is a reply to message #525480] Wed, 07 April 2010 10:35 Go to previous messageGo to next message
(If you have any follow-up questions from here then the eclipse.platform.swt
newsgroup is a more appropriate place than here).
The following snippets provide examples of creating non-standard Shells, and
some should be helpful with what you want to do. If the approach of a
transparent window+buttons proves to be difficult then you may instead want
to try creating multiple Shells with one Button each.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet219.java?view=co
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet134.java?view=co
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet180.java?view=co
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet285.java?view=co
For controls != Shell (such as Button) true transparency is not supported.
It can be somewhat faked by inheiriting the parent Control's background
color or image, as demonstrated in
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet237.java?view=co .
However I think it will be difficult to implement the case of having the
button show the content underneath it that's coming from a different parent
Shell. If you really need the buttons to be transparent then you may need
to not use real Button controls, and instead just draw fake ones on the
transparent Shell, listen for mouse down events, etc. This would look
something like the snippet below.
public class ModifiedSnippet219 {
static final String STRING = "Fake Button";
final Display display = new Display ();
final Shell shell = new Shell (display, SWT.NO_TRIM);
shell.setBackground(display.getSystemColor(SWT.COLOR_WHITE)) ;
GC gc = new GC(shell);
Point stringExtent = gc.stringExtent(STRING);
final Point size = new Point(stringExtent.x, stringExtent.y);
size.x += 20; size.y += 20;
gc.dispose();
Region region = new Region();
Rectangle rect = new Rectangle(0,0,1,1);
for (int i = 0; i < size.x; i++) {
rect.x = i; rect.y = 0;
region.add(rect);
rect.y = size.y - 1;
region.add(rect);
for (int i = 0; i < size.y; i++) {
rect.y = i; rect.x = 0;
region.add(rect);
rect.x = size.x - 1;
region.add(rect);
region.add(10,10,stringExtent.x, stringExtent.y);
shell.setRegion(region);
Listener l = new Listener() {
int startX, startY;
public void handleEvent(Event e) {
if (e.type == SWT.KeyDown && e.character == SWT.ESC) {
shell.dispose();
if (e.type == SWT.MouseDown && e.button == 1) {
startX = e.x;
startY = e.y;
if (e.type == SWT.MouseMove && (e.stateMask & SWT.BUTTON1)
!= 0) {
Point p = shell.toDisplay(e.x, e.y);
p.x -= startX;
p.y -= startY;
shell.setLocation(p);
if (e.type == SWT.Paint) {
e.gc.drawRectangle(0,0,size.x-1,size.y-1);
e.gc.drawString(STRING, 10, 10, true);
shell.addListener(SWT.KeyDown, l);
shell.addListener(SWT.MouseDown, l);
shell.addListener(SWT.MouseMove, l);
shell.addListener(SWT.Paint, l);
shell.setSize(size.x, size.y);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
region.dispose();
display.dispose ();
HTH,
Grant
"Herb Miller" <herbmiller7@gmail.com> wrote in message
news:hpfou6$6h1$1@build.eclipse.org...
> Thanks.
Re: Widget transparency [message #528236 is a reply to message #525714] Mon, 19 April 2010 15:13 Go to previous message
Grant,
Thanks for an answer to my question. I can't wait to give this a try.
By the way, will this work inside Eclipse? For instance, could I use this for a button on an Eclipse View?
Thanks.
Previous Topic:Delayed second click = Edit cell for TableViewer
Next Topic:Nested partitions/Tokens in TextEdit
Current Time: Sun Jul 20 08:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.24459 seconds
