Home » Language IDEs » ServerTools (WTP) » Generate XML from XSD(Generate XML from XSD)
Generate XML from XSD [message #525376] Tue, 06 April 2010 08:19 Go to next message
Hi!
I new to Eclipse and I have a question. I'm trying to generate a XML-file from a XSD-file using the WTP-api. But I dont know where to begin.
I saw a function in Eclipse called "Generate XML" when I right- clicked on a XSD-file. Is there any way to access this functionality programactictly?
Cheers Ola
Re: Generate XML from XSD [message #525472 is a reply to message #525376] Tue, 06 April 2010 12:32 Go to previous messageGo to next message
Hi Ola, the wizard class is
org.eclipse.wst.xml.ui.internal.wizards.NewXMLWizard and the actual
generator starts in org.eclipse.wst.xml.ui.internal.wizards.NewXMLGenerator.
These classes are not API.
Hope this helps, Valentin
"ola" <ola.adolfsson@gmail.com> wrote in message
news:hpf8t7$7r3$1@build.eclipse.org...
> Hi!
> Cheers Ola
Re: Generate XML from XSD [message #525656 is a reply to message #525472] Wed, 07 April 2010 07:52 Go to previous messageGo to next message
Thanks for the quick reply.
Hm maybe I can use the wizard to create a XML-body from a XSD. Do you know if the wizard got any limitations (such as it can't handle all XML-tags)?
Re: Generate XML from XSD [message #525798 is a reply to message #525656] Wed, 07 April 2010 15:45 Go to previous messageGo to next message
Is there a specific schema or scenario you have in mind? If you find a
problem, feel free to open a bug in bugzilla
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing
against the wst.xml component.
Cheers, Valentin
news:hphrlp$fb$1@build.eclipse.org...
Re: Generate XML from XSD [message #527376 is a reply to message #525376] Thu, 15 April 2010 01:57 Go to previous message
Thanks for the reply. I have been out of town.
I went with another aproach. Thanks for the help anyway !!
// Ola
Previous Topic:starting rhino in debug mode
Next Topic:Doubts using Java EE Modules Dependencies.
Current Time: Sun Jul 20 04:29:26 EDT 2025
Powered by FUDForum. Page generated in 0.03268 seconds
