Home » Eclipse Projects » Eclipse Platform » Looking for plug-in org.eclipse.jdt.ui on CVS
Looking for plug-in org.eclipse.jdt.ui on CVS [message #524937] Sun, 04 April 2010 04:38 Go to next message
I would like to get the eclipse project that builds the
org.eclipse.jdt.ui plugin for the galileo release from cvs, but I can
not find the cvs repository path at dev.eclipse.org
The reason I'm looking for this is to see the plugin.xml and java code
that implements the NewProject wizard for java projects so that I can
implement a wizard to create a java project, enhanced with a custom
nature and builder.
Where do I find the cvs location of the project for plug-in
org.eclipse.jdt.ui ?
Bill.
Re: Looking for plug-in org.eclipse.jdt.ui on CVS [message #524948 is a reply to message #524937] Sun, 04 April 2010 12:49 Go to previous messageGo to next message
If you are only interested in seeing the source code, you can install the Platform SDK. Then you can import the relevant plugins into your workspace and browse them as you would other java code. Look at the Feature Import section of the Plugin Development Environment Reference section in Help.
Re: Looking for plug-in org.eclipse.jdt.ui on CVS [message #524969 is a reply to message #524937] Sun, 04 April 2010 19:15 Go to previous messageGo to next message
repositories are structured by project. JDT belongs to Eclipse Project (see [1] for a list
of all projects). There is a list of all repository locations at [2]. org.eclipse.jdt.ui
is in :pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse
To see the code of the new wizard, you actually don't need the CVS project. Open the New
Wizard and press "Alt+Shift+F1" (Plug-in Spy). You can jump to the NewWizard class right
from there. But you need to use an Eclipse download package that includes the JDT sources [3].
Greetings,
Ralf
[1] http://www.eclipse.org/projects/listofprojects.php
[2] http://wiki.eclipse.org/CVS_Howto
[3] http://www.eclipse.org/downloads/packages/compare-packages
http://www.ralfebert.de/blog/
http://twitter.com/ralfebert/
Re: Looking for plug-in org.eclipse.jdt.ui on CVS [message #524985 is a reply to message #524937] Mon, 05 April 2010 00:26 Go to previous message
Dave, Ralf,
Thanks guys,
Bill.
Previous Topic:Plug-in extensions to debugging session operations?
Next Topic:is there extension points which affects cvs plugin behavior?
Current Time: Sat Jul 19 23:53:30 EDT 2025
Powered by FUDForum. Page generated in 0.37418 seconds
