Home » Modeling » EMF » How to add an RecordingCommand to the Undo/Redo menu?
How to add an RecordingCommand to the Undo/Redo menu? [message #524753] Fri, 02 April 2010 01:16 Go to next message
Originally posted by: formatzeh.gmx.de
I invoke intensive modifications of a model with a RecordingCommand.
Those modifications can affect referenced (or dependent) models in other
resources, too. With the following code I invoke those modifications:
ResourceSet rs = originalResource.getResourceSet();
TransactionalEditingDomain domain = TransactionUtil.getEditingDomain(rs);
CommandStack stack = domain.getCommandStack();
RecordingCommand command = new MyRecordingCommand(domain);
stack.execute(command);
Now, I want that this intensive RecordingCommand can be undone by
pressing Ctrl+Z or by clicking in the Edit menu on undo. The point is
that I want to undo all modifications which have been made in the whole
resourceSet and not only those from the original resource. With the code
above the undo command in the Edit menu doesn't provide any undo
functionality. How can I achieve this? If an exception occurres when
executing the command above I catch it and call command.undo(). Exactly
this I want to contribute to the edit menu. I found the following very
short description:
http://help.eclipse.org/galileo/topic/org.eclipse.emf.worksp ace.doc/references/overview/undoredo.html
But I don't know if I can solve the problem with an UndoActionWrapper or
RedoActionWrapper. And if I can I actually can't find those classes.
Ctrl+Shift+T returns an empty list when searching for those types. Which
plugin do I need in my workspace (I have the modeling version of Eclipse).
best regards,
Gilbert
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524802 is a reply to message #524753] Fri, 02 April 2010 10:55 Go to previous messageGo to next message
Gilbert,
Comments below.
The way I read the APIs, it should be recording all changes for all
objects in the entire resource set.
> With the code
> functionality.
Sounds like something else is going wrong. Most certainly it should
provide undo support.
I think the transactional support automatically does a rollback already.
> Exactly
I'm not sure what you mean be exactly this. A rolled back transaction
is a no-op. There's nothing to undo.
> short description:
I expect all this stuff just to work...
> best regards,
> Gilbert
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524821 is a reply to message #524802] Fri, 02 April 2010 09:12 Go to previous messageGo to next message
Hi Ed,
Yes, this is not the problem
Yes, transactions provide undo support. But what I want is that the user
can initiate an undo after the modifications. Therefore I can imagine
that I have to register the command in the overall workbench operation
history or something like that. When the command was executed I expect
that in the Edit menu the undo arrow is enabled but it is not in my
case. Is that explanation more understandable?
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524886 is a reply to message #524821] Sat, 03 April 2010 05:08 Go to previous messageGo to next message
--------------080301050004020707030403
Gilbert,
Comments below.
> Hi Ed,
Yes, but as I said, this should just work. All generated GMF editors
rely on this and they do have working undo support. If it's not
working, something is wrong, but you've not said anything that would
give me a clue about what's wrong. Perhaps an exception is being
thrown, a rollback is kicking in, and then there's really nothing left
to undo.
<html>
<head>
http-equiv="Content-Type">
</head>
Gilbert,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hp5bl4$va$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
</pre>
<blockquote type="cite">
<pre wrap="">The way I read the APIs, it should be recording all changes for all
</pre>
</blockquote>
<pre wrap=""><!---->Yes, this is not the problem
</pre>
<pre wrap="">Sounds like something else is going wrong. Most certainly it should
</pre>
</blockquote>
</pre>
<pre wrap="">I think the transactional support automatically does a rollback already.
</pre>
</blockquote>
</pre>
<pre wrap="">I'm not sure what you mean be exactly this. A rolled back transaction
</pre>
</blockquote>
</pre>
</blockquote>
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524926 is a reply to message #524886] Sun, 04 April 2010 05:31 Go to previous messageGo to next message
Hi Ed,
> to undo.
No rollback is executed because I see the changes in the model.
The changes have been persisted, too, i.e. they could be saved. But the
undo entry in the Edit menu still isn't activated.
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524931 is a reply to message #524886] Sun, 04 April 2010 06:46 Go to previous messageGo to next message
Now I tried the following:
TransactionalEditingDomain domain = // get it from somewhere;
IUndoableOperation operation = new MyUndoOperation(command);
IOperationHistory history =
PlatformUI.getWorkbench().getOperationSupport().getOperation History();
history.add(operation);
MyUndoOperation implements IUndoableOperation and delegates all methods
to the command which will be passed in the constructor, except one:
execute(IProgressMonitor,IAdaptable). This method just does nothing
because the command has already been executed. To make it always
undoable I return the following in the getContexts() method:
new IUndoContext[]{IOperationHistory.GLOBAL_UNDO_CONTEXT};
But this approach isn't successfull either. The undo entry in the Edit
menu still isn't activated. Is it possible to look into the operation
history of the platform? Maybe there is a view which can be installed?
best regards,
Gilbert
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524935 is a reply to message #524931] Sun, 04 April 2010 08:18 Go to previous message
Gilbert,
Hopefully someone more familiar with these APIs will answer but as I
keep suggesting all this just works in a generated GMF editor so perhaps
it would be good to look at one of those to see how they invoke
commands. Perhaps you've just not really hooked the Undo/Redo actions
to the command stack properly.
> best regards,
> Gilbert
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524939 is a reply to message #524935] Sun, 04 April 2010 05:24 Go to previous message
Hi Ed,
Ok, the whole story works for GMF editors. But what about other editors
like the generated tree editor? Within those it doesn't work.
Re: How to add an RecordingCommand to the Undo/Redo menu? [message #524942 is a reply to message #524939] Sun, 04 April 2010 06:04 Go to previous message
--------------050303000306080809070703
Gilbert,
It's clearly impossible to know from just this note thread what you've
all done to set things up. Likely some very small but important aspect
has been overlooked.
The transaction project provides downloadable examples for how to use
the framework; have you looked at those?
> Hi Ed,
<html>
<head>
</head>
Gilbert,<br>
<br>
Previous Topic:Dropping @Override from generated source
Next Topic:EMF Validation: Marker Problem
Current Time: Sat Jul 19 19:31:27 EDT 2025
Powered by FUDForum. Page generated in 0.05481 seconds
