Home » Archived » M2M (model-to-model transformation) » [QVTo] Transformation from one to N models
[QVTo] Transformation from one to N models [message #523154] Thu, 25 March 2010 07:40 Go to next message
Hi all,
I'm facing a problem regarding model transformation with QVTo and I don't know how to face it. The problem is as follows:
I have one input model that has an "a priori" undetermined number of elements of a certain type. This is:
<rootElement>
<nodeList>
<node1>
<node2>
<noden>
</nodeList>
The thing is that I have to create one output model from each of the nodeN elements. The first solution that came into my mind has been to create a transformation from the original input model to the output model. That transformation contains a mapping between the nodeN element type to the output model root type. With the TransformationExecutor class, I call it for each of the elements of the node list, like this:
Resource inputRes = ...
NodeList nodeList = ...
ExecutionContextImpl context = new ExecutionContextImpl();
TransformationExecutor executor = new TransformationExecutor(transformationURI);
for (Iterator<NodeElement> i = nodeList.iterator; i.hasNext(); )
Node node = i.next();
Resource outputRes = ...
BasicModelExtent input = new BasicModelExtent();
input.add(node);
ModelExtent output = new BasicModelExtent();
ExecutionDiagnostic diagnostic = executor.execute(context, input, output);
if(diagnostic.getSeverity() == Diagnostic.OK) {
The problem with this solution is that the transformation does not work unless I put input and output parameters to the main mapping entry operation. My first approach was not to put them and to call the mapping in a way similar to this one:
main()
inModel.rootObjects()[model::NodeElementType]->map NodeElement2OutputModel;
But it does not work (or at least it didn't work for me): it does not detect any input element. What I did then was to put parameters to the main mapping entry:
main(in node : inputModel::NodeElementType, out outModel : outputModel)
outModel := node.map NodeElement2OutputModel;
This works, but it outputs a warning message saying that using parameters in the main entry is deprecated Sad so i don't know if it will work in the future...
I don't know if there is another way to approach the problem or if I'm missing something.. any help would be very much appreciated Smile
Thank you very much in advance.
Pablo Parra.
Re: [QVTo] Transformation from one to N models [message #524642 is a reply to message #523154] Thu, 01 April 2010 12:26 Go to previous message
Hi Pablo ,
Which version of QVTo do you use?
There was bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=287711 that
led to empty result of
inModel.rootObjects()[model::SomeType]
in case objects of that type had eContainer()!=null (like in your case).
As that bug was fixed usual parameterless main() should work.
Sergey
Pablo Parra wrote:
> Hi all,
> <rootElement>
> <nodeList>
> <node1>
> <node2>
> <noden>
> </nodeList>
> input.add(node);
> output);
> main()
> main mapping entry:
> parameters in the main entry is deprecated :( so i don't know if it
> missing something.. any help would be very much appreciated :)
> Pablo Parra.
Previous Topic:[QVTo] Recursive extension of targetelement's parent element
Next Topic:[QVTO] Mapping a enumeration
Current Time: Sat Jul 19 05:33:20 EDT 2025
Powered by FUDForum. Page generated in 0.25008 seconds
