Home » Archived » P2 dev » Automatic installing and starting bundles with P2 director(Is it possible to use p2 director to install and automatically start (ACTIVE) a bundle into a target platform)
icon3.gif  Automatic installing and starting bundles with P2 director [message #524429] Wed, 31 March 2010 17:38 Go to next message
Hello everyone !
Is it possible to accomplish this scenario ?
Given :
  • a p2 repository containing the feature my.feature (referencing my.plugin)
  • 2 identical eclipse galileo installations : the first is my builder (to launch p2director) and the second is my target
I want to perform this :
  • deploy my.plugin into my target eclipse platform, using p2director, and also automatically start this plugin
easy right ?
It works with
java -jar C:\tmp\builder\plugins\org.eclipse.equinox.launcher.jar -application org.eclipse.equinox.p2.director -repository file:C:/simpleupdatesite/ -installIU my.feature -destination c:\tmp\target
But I want to do this WHILE the target platform is launched and alive, without re starting it (I want it to be "hot deployed")
I tried playing with the touchpoints (p2.inf) ; I know they are loaded fine, for example such a p2.inf will make my.plugin active... if I relaunch my target platform
instructions.install=\
	markStarted(started:true);
To sum up with, is it posssible to add IU(s) to a running equinox and start them (without stopping/restarting the running equinox)
Thank you all for your answers !
[Updated on: Wed, 31 March 2010 17:41] by Moderator
Re: Automatic installing and starting bundles with P2 director [message #524441 is a reply to message #524429] Wed, 31 March 2010 19:38 Go to previous message
Bonsoir Anthony,
if your IU installation is successful, bundles.info file will be updated.
from the OSGi console of your target installation, you can perform
osgi> confapply [<config URL>]
example: osgi> confapply file:<config dir>/bundles.info
and it will enable the changes from bundles.info to the OSGi Framework.
But it would be great if it was possible to do it directly from a P2 touchpoint instruction or if it was automatically done from the installIU command.
Sebastien
Previous Topic:"Install New Software...." fails when "osgi.configuration.area" is set in config
Next Topic:Eclipse 3.5.2, P2 Touchpoint, chmod
Current Time: Sat Jul 19 21:32:42 EDT 2025
Powered by FUDForum. Page generated in 1.03592 seconds
