Home » Eclipse Projects » Remote Application Platform (RAP) » Externailze Css(Externalize Css)
Externailze Css [message #523212] Thu, 25 March 2010 10:43 Go to next message
Is there a way to externalize the css file used for theming ?
I try to use ThemeManager.getInstance().registerTheme method...
Re: Externailze Css [message #523227 is a reply to message #523212] Thu, 25 March 2010 11:18 Go to previous messageGo to next message
Could you explain what you mean by "externalize"?
Ralf
Re: Externailze Css [message #523236 is a reply to message #523227] Thu, 25 March 2010 11:50 Go to previous messageGo to next message
By externalize css file, I mean to work with a JVM argument which will give the path to a file located on the disk outside
of the RAP application.
This will allow a person to change the css file without having to release our RAP application war.
Best regards !
Re: Externailze Css [message #523254 is a reply to message #523236] Thu, 25 March 2010 12:25 Go to previous messageGo to next message
> Best regards !
Honestly, I don't think that CSS files should be distributed separated
from the application since the theme is a non-trivial part of the
application itself. What is your use case?
Since *.war files and *.jar files are in zip format, couldn't this
person simply replace the theme file within the war archive?
Ralf
Re: Externailze Css [message #523455 is a reply to message #523212] Fri, 26 March 2010 10:26 Go to previous message
Zhang,
Depending on what kind of Server application you use (Glass fish, Tomcat). You have access from the outside world. Al touch I don't think its something you want.
In tomcat for instance the war file gets unpacked in TOMCAT_HOME/webapps/ (name of the war file you uploaded).
It would be better to make an editor in your application that directly change it (that the best solution if you want to on the fly change something).
Re: Externailze Css [message #523491 is a reply to message #523455] Fri, 26 March 2010 06:40 Go to previous message
Please note that the theme files are read on application (not session)
startup, changes at runtime will not take effect until the application
is restarted.
Ralf
Martijn Cremer wrote:
> Zhang,
> something).
Previous Topic:How-To BrowserHistory
Next Topic:RAP with JPA/Eclipselink Shell for Glassfish
Current Time: Sat Jul 19 09:55:51 EDT 2025
Powered by FUDForum. Page generated in 0.03067 seconds
