Home » Eclipse Projects » Rich Client Platform (RCP) » Command Shortcut on Dialog
Command Shortcut on Dialog [message #523163] Thu, 25 March 2010 08:00 Go to next message
I have created a command in plugin.xml and used that to add a toolbar button
to a modal dialog window. I can click this button and it will invoke the
command. Now I want to assign a shortcut key to this command using
plugin.xml, I did this using Key bindings but its not working. When I add
this command to the Workbench toolbar, the shortcut key works properly.
Any suggestions on how to assign a shortcut key to a command added to a
modal dialog toolbar?
Thanks and Regards
Mustufa Kasidwala
Re: Command Shortcut on Dialog [message #523262 is a reply to message #523163] Thu, 25 March 2010 12:55 Go to previous messageGo to next message
You key's context might be just window. It should be dialog&window
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Command Shortcut on Dialog [message #525652 is a reply to message #523262] Wed, 07 April 2010 02:42 Go to previous message
Thanks Prakash,
Setting the context Id to dialogAndWindow worked properly.
Thanks and Regards
Mustufa Kasidwala
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:hog4ik$582$1@build.eclipse.org...
>> button
> - Prakash
Previous Topic:Using Java 6 Splash Screen with RCP
Next Topic:Warn about wrong Java version
Current Time: Sun Jul 20 05:29:45 EDT 2025
Powered by FUDForum. Page generated in 0.26178 seconds
