Re: Preferences->Label Decorations->Git won't "stick" [message #525540 is a reply to message #525439] |
Tue, 06 April 2010 15:53   |
> news:hodrgc$qeo$1@build.eclipse.org...
>> Hi,
>> I can't get the label decorations to stick. I select the
>> Preferences->Label Decorations->Git check box, but the setting won't apply
>> and just reverts back to unchecked.
>There is a known bug in case that there is a .git folder somewhere below a
>eclipse project (https://bugs.eclipse.org/bugs/show_bug.cgi?id=297163). Do
>you have that in your case?
I just checked, and I definitely have that case. In fact, I have three. Here's the directory structure (w company specifics x'd out):
projects/xxx/mx/.git
projects/xxx/dxxxxx/.git
projects/xxx/mxxxx/.git
projects/xxx/.project
Is this the same as the bug you mentioned?
>> Also, Team->Commit... is greyed out for all files, as well as Push.
>> However, compare and history work fine... (if this is a separate problem,
>> I will post separate topic).
>Do you have any entries in the error log?
Which/where error log?
>Stefan
Thank you for your help.
David
[Updated on: Tue, 06 April 2010 18:03] by Moderator
Re: Preferences->Label Decorations->Git won't "stick" [message #578914 is a reply to message #525439] |
>"buzzkill" <mailto:destrozyk@yahoo.com> wrote in message
> news:hodrgc$qeo$mailto:1@build.eclipse.org...
>> Hi,
>Stefan
David
FUDForum. Page generated in 0.04260 seconds
