Home » Eclipse Projects » Standard Widget Toolkit (SWT) » OLE Understanding Excel Automation(writing values into cells - selecting specific sheets)
icon5.gif  OLE Understanding Excel Automation [message #521629] Thu, 18 March 2010 06:51 Go to next message
I want to create an Excel OLE object, and write some values into this object (in a definite worksheet). How can I do this? I have found on a Japanese side the following example:
public class OleExcel extends OleClientSite {
	public static final String ID = "ExcelSheet";
	private static final int CELL_VALUE_ID = 0x00000006;
	private static final int CELL_ID = 0x000000c5;
	private static final int SHEET_ID = 0x000001e5;
	private OleAutomation cell;
	public OleExcel(Composite parent, int style, File file	) {
		super(parent, style, file);
		OleAutomation workbook = new OleAutomation(this);
		OleAutomation worksheet = workbook.getProperty(SHEET_ID,
				new Variant[] { new Variant(1) }).getAutomation();
			cell = worksheet.getProperty(CELL_ID,new Variant[] { new Variant("A1") }).getAutomation();
			cell.setProperty(CELL_VALUE_ID, new Variant("Testeintrag"));
But where do the ID's? I would prefer to solve the whole thing, like"... GetIDsOfNames (new String [] (" xxx ")".
Someone an idea? How I write in certain sheets?
I have begun linke this:
	public void createPartControl(Composite parent) {
		try {
			try {
				OleFrame frame = new OleFrame(parent, SWT.NONE);
				site = new OleClientSite(frame, SWT.NONE, "Excel.Sheet");
				//get an Excel workbook
			     OleAutomation workbook = new OleAutomation(site);
			     // activeSheet
			     int [] ids = workbook.getIDsOfNames(new String[]{"ActiveSheet"});
			} catch (SWTError e) {
				System.out.println("Unable to open activeX control");
				return;
			return;
I'm really desperate. I can´t find any reasonable docu Sad
greetings, mo
[Updated on: Thu, 18 March 2010 07:19] by Moderator
Re: OLE Understanding Excel Automation [message #522477 is a reply to message #521629] Mon, 22 March 2010 13:55 Go to previous message
I think you're looking for a reference like
http://msdn.microsoft.com/en-us/library/aa272268(office.11).aspx . As an
added bonus, here's a utility class that I've found to be quite helpful in
the past. You can pass it any OleAutomation and it will write to stdout all
of its properties and methods with ids and descriptions (if available).
public class OLEDisplayAPI {
public static void printAPI(OleAutomation auto) { // <---
TYPEATTR typeattr = auto.getTypeInfoAttributes();
printMethods(auto, typeattr);
printProperties(auto, typeattr);
private static void printProperties(OleAutomation auto, TYPEATTR typeattr) {
if (typeattr != null) {
if (typeattr.cVars > 0) System.out.println("\n\nVariables :");
for (int i = 0; i < typeattr.cVars; i++) {
OlePropertyDescription data = auto.getPropertyDescription(i);
System.out.println("PROPERTY (id = " + data.id + ") :");
System.out.println("\tName : " + data.name);
System.out.println("\tType : " + getTypeName(data.type) + "\n");
private static void printMethods(OleAutomation auto, TYPEATTR typeattr) {
if (typeattr.cFuncs > 0) System.out.println("Methods:");
for (int i = 0; i < typeattr.cFuncs; i++) {
OleFunctionDescription data = auto.getFunctionDescription(i);
String argList = "";
int firstOptionalArgIndex = data.args.length -
data.optionalArgCount;
for (int j = 0; j < data.args.length; j++) {
argList += "[";
if (j >= firstOptionalArgIndex) argList += "optional, ";
argList += (getDirection(data.args[j].flags) + "] "
+ getTypeName(data.args[j].type) + " " + data.args[j].name);
if (j < (data.args.length - 1)) argList += ", ";
System.out.println(getInvokeKind(data.invokeKind) + " (id = " +
data.id + ") : ");
System.out.println("\tSignature : " + getTypeName(data.returnType) +
" " + data.name + "(" + argList + ")");
System.out.println("\tDescription : " + data.documentation);
System.out.println("\tHelp File : " + data.helpFile + "\n");
private static String getTypeName(int type) {
switch (type) {
case OLE.VT_BOOL: return "boolean";
case OLE.VT_R4: return "float";
case OLE.VT_R8: return "double";
case OLE.VT_I4: return "int";
case OLE.VT_DISPATCH: return "IDispatch";
case OLE.VT_UNKNOWN: return "IUnknown";
case OLE.VT_I2: return "short";
case OLE.VT_BSTR: return "String";
case OLE.VT_VARIANT: return "Variant";
case OLE.VT_CY: return "Currency";
case OLE.VT_DATE: return "Date";
case OLE.VT_UI1: return "unsigned char";
case OLE.VT_UI4: return "unsigned int";
case OLE.VT_USERDEFINED: return "UserDefined";
case OLE.VT_HRESULT: return "int";
case OLE.VT_VOID: return "void";
case OLE.VT_BYREF | OLE.VT_BOOL: return "boolean *";
case OLE.VT_BYREF | OLE.VT_R4: return "float *";
case OLE.VT_BYREF | OLE.VT_R8: return "double *";
case OLE.VT_BYREF | OLE.VT_I4: return "int *";
case OLE.VT_BYREF | OLE.VT_DISPATCH: return "IDispatch *";
case OLE.VT_BYREF | OLE.VT_UNKNOWN: return "IUnknown *";
case OLE.VT_BYREF | OLE.VT_I2: return "short *";
case OLE.VT_BYREF | OLE.VT_BSTR: return "String *";
case OLE.VT_BYREF | OLE.VT_VARIANT: return "Variant *";
case OLE.VT_BYREF | OLE.VT_CY: return "Currency *";
case OLE.VT_BYREF | OLE.VT_DATE: return "Date *";
case OLE.VT_BYREF | OLE.VT_UI1: return "unsigned char *";
case OLE.VT_BYREF | OLE.VT_UI4: return "unsigned int *";
case OLE.VT_BYREF | OLE.VT_USERDEFINED: return "UserDefined *";
return "unknown " + type;
private static String getDirection(int direction) {
String dirString = "";
boolean comma = false;
if ((direction & OLE.IDLFLAG_FIN) != 0) {
dirString += "in";
comma = true;
if ((direction & OLE.IDLFLAG_FOUT) != 0) {
if (comma) dirString += ", ";
dirString += "out";
comma = true;
if ((direction & OLE.IDLFLAG_FLCID) != 0) {
dirString += "lcid";
comma = true;
if ((direction & OLE.IDLFLAG_FRETVAL) != 0) {
dirString += "retval";
return dirString;
private static String getInvokeKind(int invKind) {
switch (invKind) {
case OLE.INVOKE_FUNC: return "METHOD";
case OLE.INVOKE_PROPERTYGET: return "PROPERTY GET";
case OLE.INVOKE_PROPERTYPUT: return "PROPERTY PUT";
case OLE.INVOKE_PROPERTYPUTREF: return "PROPERTY PUT BY REF";
return "unknown " + invKind;
Grant
<mo84@gmx.de> wrote in message news:hnt0jd$lv$1@build.eclipse.org...
> I'm really desperate. I think any reasonable docu :(
> greetings, mo
Previous Topic:Excel ActiveX DisplayAlerts property
Next Topic:Swing AWT and SWT Browser
Current Time: Sun Jul 20 09:12:42 EDT 2025
Powered by FUDForum. Page generated in 0.64630 seconds
