Home » Eclipse Projects » Eclipse Platform » Decorator performance
Decorator performance [message #521300] Wed, 17 March 2010 04:26 Go to next message
I add a org.eclipse.ui.decorators extension point to get decorator for elements in my trees. The method decorate() is called for each elements, and in this method I have my own treatment to manage the display of the decorator.
The problem is that when I have several elements in my trees, it take a lot of time to decorate elements, and the application is stuck during a long time.
Is there a way to improve the management of the decorator, when there is a lot of elements?
Thanks in advance,
David.
[Updated on: Wed, 17 March 2010 05:08] by Moderator
Re: Decorator performance [message #521675 is a reply to message #521300] Thu, 18 March 2010 09:23 Go to previous messageGo to next message
Hello !
I have the same problem, and for the moment my solution is to create markers/decorators in a separated thread...
If anyone have another solution ?
Thanks!
Sophie
Re: Decorator performance [message #521892 is a reply to message #521675] Fri, 19 March 2010 04:13 Go to previous message
@Sophie
How to you create your decorator in a separate thread? Because you just have a XXXDecoratorLabel class which implements "ILightweightLabelDecorator", and you wrapp it with the label provider.
I think the problem is the refresh treatment of the decorator, after the decorate() method is called for each element of the tree. But it should be managed in a specific thread which doesn't blocked the application.
Thanks for your help.
David.
Previous Topic:Not able to download older plugin dependencies
Next Topic:ACTION_ARRANGE_ALL: how to execute it from custom Action?
Current Time: Sat Jul 19 20:37:07 EDT 2025
Powered by FUDForum. Page generated in 0.05253 seconds
