Home » Archived » M2M (model-to-model transformation) » [ATL] Helper def with super-imposition
[ATL] Helper def with super-imposition [message #520432] Fri, 12 March 2010 06:05 Go to next message
We can't define definitions helpers anymore in super-imposed transformations nor super-impose an existing helper definition.
Is it an intended behavior and if so, why ?
I don't quite see why it would be a bad practice.
What do you think ?
Re: [ATL] Helper def with super-imposition [message #521709 is a reply to message #520432] Thu, 18 March 2010 10:30 Go to previous messageGo to next message
--------------040500050404050401040904
Hi Sylvain,
I'm not sure to understand well your problem. Could you provide a test
case about it ? thanks in advance.
William
Le 12/03/2010 12:05, Sylvain EVEILLARD a écrit :
> What do you think ?
Ne manquez pas notre prochaine formation ATL inter entreprises:
ATL - Paris - du 14 au 15 avril 2010
Pour plus de dates et pour le détail de cette formation:
http://www.obeo.fr/pages/formations/fr
Don't forget our next ATL training:
ATL - Paris - 2010 April from 14th to 15th
More dates and training program on:
name="william_piers.vcf"
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTAgNTMNCnVy bDpodHRwOi8v
d3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------040500050404050401040904--
Re: [ATL] Helper def with super-imposition [message #521716 is a reply to message #520432] Thu, 18 March 2010 10:51 Go to previous messageGo to next message
helper def : fakeDef : String = '';
in a superimposed transformation crashes the VM.
Re: [ATL] Helper def with super-imposition [message #521731 is a reply to message #521716] Thu, 18 March 2010 11:39 Go to previous messageGo to next message
--------------030503000602050903020503
Which version of ATL do you use ? I tried with HEAD and the latest build
and it works.
--------------030503000602050903020503--
Re: [ATL] Helper def with super-imposition [message #521739 is a reply to message #520432] Thu, 18 March 2010 11:54 Go to previous messageGo to next message
3.0.1.v200909220532
Good news if it's related to the version though
[Updated on: Thu, 18 March 2010 11:54] by Moderator
Re: [ATL] Helper def with super-imposition [message #521754 is a reply to message #521739] Thu, 18 March 2010 12:30 Go to previous messageGo to next message
--------------030407030801020600050105
It works with this version too.
I attached the basic superimposition test I used, maybe you could try to
reproduce the bug with (modify it and resend it then).
Thanks in advance,
William
Le 18/03/2010 16:54, Sylvain EVEILLARD a écrit :
> 3.0.1.v200909220532
--------------030407030801020600050105--
Re: [ATL] Helper def with super-imposition [message #521755 is a reply to message #521754] Thu, 18 March 2010 12:31 Go to previous messageGo to next message
--------------030803020604050203060509
> Thanks in advance,
> William
>> 3.0.1.v200909220532
Content-Type: application/octet-stream;
name="SuperimpositionTest.zip"
filename="SuperimpositionTest.zip"
UEsDBBQACAAIALmBcjwAAAAAAAAAAAAAAAAUAAAAU3VwZXJpbXBvc2UvLnBy b2plY3SNkD0O
wjAMhWeQuEPVnQSYGEIrAWJkKRwgpFYVlD8lKeL4JGlKVSY2f8/P9pNJ/Zai eIF1XKtDuUWb
sgDFdMtVdyjvt8t6X9bVakmM1U9g/gyOWW58cAd1QRSVUDW9Acul0Q4ITkps MS0lKF8RPFZR
zXtcAjyjR89F2xhgkTKewihVbVLyNW07BExw4wDJnUTUC0Rbj5IfbOTjUE5h wiy1XR9TuMx4
LhD8ey8rY6Bw3PcWsnuAf7JckzNGSRNp8bTq+4L5Yz9QSwcINwdbLcYAAACX AQAAUEsDBBQA
CAAIALCKcjwAAAAAAAAAAAAAAAAUAAAAU3VwZXJpbXBvc2UvYmFzZS5hc23F WNty2zYQfU5n
+g+M+mB3OpZ4l+TIzcRpM2PXl7py+qqhScjhBAQZklLtfn0BigQoEguSVjx9 sSTsweKy5+wu
vHj/FGFti9IsjIl2ph0ZY/1IQ8SPg5A8soGL5e3JbObMT4wj7f2vP/6w8LJI I16Ezkb6iP5+
s/AT9kE/Y5LlHsm1rYc31PzgZaE/msiNOCRfM8h4c596JAsRya8obInydxDS jzFkuoQMa+8r
+g2tIXPkhQSyfYAMtz7+00vpreRp+C8K7p8TBEF/Il4ebkHzxxhj5Oc0HODB xhnKb+hax8uf
T/9W7GgZRglGqr1Q0AfyrFzod4wiGgjm5fhSsV4zZOAVjleryMv9LyhdrY4V DhkQPSFfjXJP
LevEPbV1CJAhDIZ6tUpRFuMtWq0giAFfTuzji+yPkAS3a3Yz56CLWX+ejx9R 8f38eRlvUh+V
t88ifbePBiVRbuwzCdA6JCg4Vm3N6be1Yl/3Xkr/fkrjaLc3dmhQZMYUslhg qJbo24amHpCt
pooqPJLKbd1djkPi4w3Lbgx4p0KusZfniByrYOBmiw/IWG72HkUJeBkDIsOS QdAOz1JxESyD
w7LgAu1UcRQHCKsEWokYTLfMwXCBZOfPf20wGiIMtmcvSfDzbs+NWcojiKNC mGuV8fP1FWS6
uAE9Xt9+evsRe1kWrkOUvht7GF8UEB9lLMzF2cEA752uL5dovi9u9frD/dVb 9k11LSFJNmCa
b3r2gqCR0VTFJN7kw3zvyN/Lt4RT1AH7bjY5ca5wY5inhnlC/5pgiaBG68Sw T22YWIKPPQ87
ICu0KgjIFTDZ95lsgaeDK9Qv6tphFVdL/4JFhENMsCgwo1NAwPorvKgglsEg NhxmDpl3LqSE
2GoE5kJeTHY994ImBhyU3bgx0nLapPEyuWe0KqMtMTpNY5yg1GMtaAlwR3xH OXrKSzQPTrLr
fOkjYvd70hygrwlUfHuzoKSiD4hJ+SvZZF80yrSzURWA+ticjxH0T/U12CRt pKFzqE/TZDlo
jNSTzMPWtNRr1gZtPkgT7G5MTIZuRG9PcjonGU7fM3GnBuC0tn+3G8LJMOHB XlDCIrKJHlCa
ew+4YgAmSAuDoi3WHtBjSIrZ9M0Z7LmRTV7gmC659dKQDe053SItw3HOrq3S w5z710v3Zs29
1NNiwqkvFYKpD1JCbaByYDS0plYLjr1gd8EmFKbHNqNEWExB8XBdDkHMe2wT Qrp8zbstE1jN
7rRXd3s7n4p9xnlcDtbSRJwoPdUmzSWasPS+QpF6D3NGDMTFlMcpKh1DgRJ+ LNl5LVM2KIJF
CdxYtAaze6rv5bIyK1lZDpcVpVJDV72FOJdMMPgSLjzhpcq1pt9duW2MxTHW rI+8v6MApcgu
ys1fnTYqErgDOSDDc1raOoh/KWVox/dKbY8IgW3+ryEwDr0i67WuSCIGkadt W8Jm2+mRncEy
2qE02wUT8etFzpDkXKeM3Gxgxj00f9rD8qcy0rVAytp+WxSHdUiCCLUhjqzf d/qU5+4+SkY4
57CngpSvjqjt0klOR3KveXI6PLmyW+64+tqZaitN9yblEsTsxUIRTwNH8JeV 3V0HIK6rgrki
5zPG72CiFTpYdjQClX+3ci8rQq/65HCHVSFV4+KKYjP0zSGlpYi6K4Ijb4W7 nLoyp7bMqetI
nLpSBfTov7nqbdl7wJVua9qVQRz1LGnPn8k2Uj1x+ivHrT2qK+XU/ifBYXMJ zGzBpjWBVb2+
0dbh1JB4s9swU8CqMlb7fwWHWRKY24bZkkWnbZgonVWKMOaqTDKrhKsfnEgs nkhEMzttupd2
s7XMY6kmKDOPbALPbVPJG0sflKoWE8p9+vkfUEsHCOy+Y11rBQAAQyAAAFBL AwQUAAgACACw
inI8AAAAAAAAAAAAAAAAFAAAAFN1cGVyaW1wb3NlL2Jhc2UuYXRsXY4xD4Iw EIXn3q84JzSG
1ugmkji4kIgmKrNBPKSxUFJKGIz/3VKdXC733rv35cIQt02XnRLM0n1cWduu hRiGgVOhZNsR
1+Yh+lotxYov+EK4K4Ba33tFeMs7WURQGMot4TG74HqkYGl0jcnhqyKAilRL Bu9UOqvMn7Tz
29ka2TwwxsCDAndpRqyjk8IXsJEDjMmm7e0XNknHDJjV6ALd278Ep85mTV4T bkL0Re7VHINr
4KatZJf67/nvEVeYwRs+UEsHCH26KczAAAAACAEAAFBLAwQUAAgACABrgnI8 AAAAAAAAAAAA
AAAAFQAAAFN1cGVyaW1wb3NlL2lucHV0LnVtbFWQT0/DMAzF70h8h8j3Jt0Q EqoadpgKDMiJ
TXCrqtRqo+UfS7aWb0/WSdV2tP388/MrV6PR5ISHoJzlsKA5ELTStcp2HHbb l+wJVs/3d+XR
6EK4FjUZjSrmhSVdQOpoG4rU59DH6AvGguzRNNSZjrpDx4JHyX7Ehl3JE3CW D8NAUWrlA076
NFuyB5rTnO3EJ0wnVcuhfv8SUWw/+qrNxPG0F7bOghiA2MYgh4ghTh4hOSak 9I3cNx22lUaD
Nk6Y+OeT8vzNWjchXLH12/q1urD1Rj7Wv9+uGm/Ylw12joPNeaTqH1BLBwjR 5cNw5AAAAEUB
AABQSwMEFAAIAAgAZ4tyPAAAAAAAAAAAAAAAABYAAABTdXBlcmltcG9zZS9v dXRwdXQudW1s
TY7LCsIwFET3gv9Q7r5Jq4g1GN0oKFoURdGVSHOtgTxK09rq1xu6ELczZx7T eatV8MLSSWs4
xCSCAE1mhTQ5h/VxFybJaBLGMJ/1e9NaK5ZagSpotWS/1IDE4BVlHPM6h2dV FYxSlz1R34nV
ObFlTl2BGb2ka/qH+8If3jQNwUzJwmHHe29AhyQiET2lW+gmpeBwW+2v59Ni Uy5FKKLH+zD+
CFM3EJi7Rg4Vuqr7eHN1gSVQf/wLUEsHCNS0ila3AAAA5gAAAFBLAwQUAAgA CAC1inI8AAAA
AAAAAAAAAAAAHAAAAFN1cGVyaW1wb3NlL3N1cGVyaW1wb3NlZC5hc23lVktv m0AQPqdS/wOi
h7gHPwA/U9Io6UNKWiWN7PZqrWHsrLLsUli7SX99FxsvxGbWzqPqoRdjZr6d GWa+b8A/uYuY
tYAkpYJbx9ah02gdWsADEVI+ywznw6t6v98Z1J1D6+T961c+SSOLkwiO7Zat 7g/8IM4u6ip4
KgmX1oKwuXJPSEoDu1ntZJTfppjzcpQQnlLg8quCDUG+w5CBYJjrAnNMyS18 hCnmjgjlmO8U
c1wF7BtJVFdkQn9DOLqPAYO+4UTSBer+IBiDQKpxoA/WSEFeqly14dujH4aK hjSKGZhqUaBT
fm9M9IlBpAaRRaldGPKl8xgSzLk5T7S/jfE4IjK4gWQ8rhmyZUC4g8CM6h55 Xr171G6hRQND
eTAeJ5AKtoDxGIM4eOdEwM7TL5SHV9OsbWdoiP7+ImjMYPn/7H4o5kkA+Wgy Glw/RKN6yQv7
zkOYUg5hzVRaZ7/SlnWNSKJ+PyciWtWWPTSqQKeHeTx0VEP4OVd7CaWya6KK nqSxrOuLBuUB
m2erLwNem5BTRqQEXjPB0GKXF8yZFzuCKEab8YjJZJsi3B7P0NCIbL3jstAC xSEraa78fnP1
gvCnFFiYvzoc25Jqo+ixPXB6a2e7wtnZdAq1d0i2L3NA19ZVSbiTOVozLl6t afXGW903Nw3q
1QfLfwe+apl62zXzu3ie3liqj8f2WrNl20DbOPxa/w3n8TbSaWloQBjLjY5t PuQ+L6dnzlky
trVRbf+VrTiMdUTvitKpzu5T3X0fSgd1kKClB+jthuil29TT9tUXCfB5NIFE kglbU4BxsGio
jgxsawIzypcJ1BdSWF5jzarDPhMq5YIkNDM9CLoAK2VCZp9QOWvdlo7fysO7 pfCVkfym5n6l
ElznUVIoGdYB3A2xmeXCBAlXDXZdZAazbUoVY3ELI53mpvauQAUhKtOXoneq FFbyd7ez9/YO
XqyEmZAiNxZUjkVsjFQc8loVmvCcfYVSGZ3KjBigxSRFAnlgbFBFHK/qeb2q +XnFsBSBN5KW
YJ091fd0WblrWXldLSvFrg1d7S3EQcUBR6fo4Qeeqlyv/+LK3cZ4GuMN9pH3 CwqwErmDcsVX
/F+jjYkE3UdyoAqvadl2UPxTKdN2X+q759/0t+48twHef9UAv6nEqK5/AFBL BwhJ5ejHYgMA
AMIRAABQSwMEFAAIAAgAtYpyPAAAAAAAAAAAAAAAABwAAABTdXBlcmltcG9z ZS9zdXBlcmlt
cG9zZWQuYXRsJYzLDsIgFET3fMXddVVodFfSxIWbJj4SlQ9AemlJaSE8wu+L ups5czJtC6c9
iscI4noZlpR8z1gphaKyxkekLswsb/bAjrSjHasWIZubskV4y2gUJyqgTAh3 8YL++wI6uA3G
279xQha0HgNMqCvScsXzLz1TMPsMAzQx173hQD5QSwcIXd3iO4AAAACOAAAA UEsDBBQACAAI
AJaKcjwAAAAAAAAAAAAAAAAnAAAAU3VwZXJpbXBvc2Uvc3VwZXJpbXBvc2l0 aW9uIHRlc3Qu
bGF1bmNolZRbj9owEIXfK/U/RH7fJKVSVa2WrhCENlIuCMK+IhMmYNWxLV+W 5d/XIWwa2ISm
T0ST882ZiQ9+en4rqfMKUhHOxuiL6yMHWM53hO3HaJ3NH74jR2nMdphyBmPE OHr+8fnTE8WG
5YcpZwXZG4m1xR19ElbB5d6FnBKhwC1HpYs1dfFOuzVh+1aVTGKmCi7LM4mq jkpL+3Ki7c/W
aHB+w2mMJlnkzAkFJ8ElIOcVU2MtvJURIEkpuAJvi62RbYm8u11e4gYP4vmD EpCTguRV/S64
mabxIoyCZYNbr5Hvf6uxLecUMLvhwtVmGczDJEx+NliBqYIaKrG4BZgwGl3e BUzL06WeNPw6
jmraa+Pd7SKyVX1WMd8BdX7ZI6UgOywrn9aXGux57pvZCNxfI05nQRQmi3XW DNgSprZ8pbSF
Hml7zjjIJh/kA2ZORRU/1TGxMkJwqa3JaKVBAq/CrXoOs8UJmyIdvEFuqs4Z aaW2l0kXWZgm
m2kUTJaD1bNgGb4Es0avpemUY0r5MWR2h/MBLaGw27B8yC5Kg+hSDfmwRncH un3A/5PoBdaH
+8G6uhRI9X9yTUn/FbIrip+n7sPagTOSPB60Fo+edzwem/vO3n2epUfeV9d3 fa9/QUqUvtmw
NQh6l9TuXaOqv887F6vy4nPVt658vKht/Q9QSwcIahUFwfoBAAD4BQAAUEsB AhQAFAAIAAgA
uYFyPDcHWy3GAAAAlwEAABQAAAAAAAAAAAAAAAAAAAAAAFN1cGVyaW1wb3Nl Ly5wcm9qZWN0
UEsBAhQAFAAIAAgAsIpyPOy+Y11rBQAAQyAAABQAAAAAAAAAAAAAAAAACAEA AFN1cGVyaW1w
b3NlL2Jhc2UuYXNtUEsBAhQAFAAIAAgAsIpyPH26KczAAAAACAEAABQAAAAA AAAAAAAAAAAA
tQYAAFN1cGVyaW1wb3NlL2Jhc2UuYXRsUEsBAhQAFAAIAAgAa4JyPNHlw3Dk AAAARQEAABUA
AAAAAAAAAAAAAAAAtwcAAFN1cGVyaW1wb3NlL2lucHV0LnVtbFBLAQIUABQA CAAIAGeLcjzU
tIpWtwAAAOYAAAAWAAAAAAAAAAAAAAAAAN4IAABTdXBlcmltcG9zZS9vdXRw dXQudW1sUEsB
AhQAFAAIAAgAtYpyPEnl6MdiAwAAwhEAABwAAAAAAAAAAAAAAAAA2QkAAFN1 cGVyaW1wb3Nl
L3N1cGVyaW1wb3NlZC5hc21QSwECFAAUAAgACAC1inI8Xd3iO4AAAACOAAAA HAAAAAAAAAAA
AAAAAACFDQAAU3VwZXJpbXBvc2Uvc3VwZXJpbXBvc2VkLmF0bFBLAQIUABQA CAAIAJaKcjxq
FQXB+gEAAPgFAAAnAAAAAAAAAAAAAAAAAE8OAABTdXBlcmltcG9zZS9zdXBl cmltcG9zaXRp
b24gdGVzdC5sYXVuY2hQSwUGAAAAAAgACAA2AgAAnhAAAAAA
--------------030803020604050203060509--
Re: [ATL] Helper def with super-imposition [message #522641 is a reply to message #520432] Tue, 23 March 2010 09:27 Go to previous messageGo to next message
unfortunately I can't download the file, could you upload it somewhere ?
Re: [ATL] Helper def with super-imposition [message #522849 is a reply to message #522641] Wed, 24 March 2010 04:06 Go to previous messageGo to next message
--------------000307060408030300000009
I attached files separately, maybe it will be better ? They have to be
in a "Superimpose" ATL project (for the attached launch config).
name="base.atl"
filename="base.atl"
LS0gQG5zVVJJIFVNTD1odHRwOi8vd3d3LmVjbGlwc2Uub3JnL3VtbDIvMy4w LjAvVU1MCgpt
b2R1bGUgYmFzaWM7CmNyZWF0ZSBPVVQgOiBVTUwgZnJvbSBJTiA6IFVNTDsK CmhlbHBlciBk
ZWYgOiBmYWtlRGVmIDogU3RyaW5nID0gJ2Jhc2ljJzsKCnJ1bGUgbW9kZWwg ewoJZnJvbQoJ
CWlucHV0IDogVU1MIU1vZGVsCgl0byAKCQlvdXRwdXQgOiBVTUwhTW9kZWwg KAoJCQluYW1l
IDwtIGlucHV0Lm5hbWUgKyAnXycgKyB0aGlzTW9kdWxlLmZha2VEZWYKCQkp Cn0K
Content-Type: text/xml;
name="input.uml"
filename="input.uml"
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmi:id="_JSMtMTKhEd-MuvkMn_-sMw" name="testModel">
<packagedElement xmi:type="uml:Class" xmi:id="_lHCGETKhEd-lIc5_qWoExw" name="testClass"/>
</uml:Model>
name="superimposed.atl"
filename="superimposed.atl"
ZWYgOiBmYWtlRGVmIDogU3RyaW5nID0gJ3N1cGVyJzsgCg==
name="superimposition test.launch"
filename="superimposition test.launch"
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.m2m.atl.adt.launching.atlTransformation">
<stringAttribute key="ATL File Name" value="/Superimpose/base.atl"/>
<stringAttribute key="ATL VM" value="EMF-specific VM"/>
<stringAttribute key="ATL_COMPILER" value="atl2006"/>
<booleanAttribute key="IS_REFINING" value="false"/>
<mapAttribute key="Input">
<mapEntry key="IN" value="UML"/>
</mapAttribute>
<mapAttribute key="Libs"/>
<mapAttribute key="Model Handler">
<mapEntry key="UML" value="EMF"/>
</mapAttribute>
<mapAttribute key="ModelType">
<mapEntry key="IN" value="MODELINPUT"/>
<mapEntry key="OUT" value="MODELOUTPUT"/>
<mapEntry key="UML" value="METAMODELOUTPUT"/>
</mapAttribute>
<mapAttribute key="Options">
<mapEntry key="supportUML2Stereotypes" value="false"/>
<mapEntry key="printExecutionTime" value="false"/>
<mapEntry key="OPTION_CLEAR" value="false"/>
<mapEntry key="OPTION_DERIVED" value="true"/>
<mapEntry key="allowInterModelReferences" value="false"/>
<mapEntry key="step" value="false"/>
</mapAttribute>
<mapAttribute key="Output">
<mapEntry key="OUT" value="UML"/>
</mapAttribute>
<mapAttribute key="Path">
<mapEntry key="IN" value="/Superimpose/input.uml"/>
<mapEntry key="OUT" value="/Superimpose/output.uml"/>
<mapEntry key="UML" value="uri:http://www.eclipse.org/uml2/3.0.0/UML"/>
</mapAttribute>
<listAttribute key="Superimpose">
<listEntry value="/Superimpose/superimposed.asm"/>
</listAttribute>
</launchConfiguration>
--------------000307060408030300000009--
Re: [ATL] Helper def with super-imposition [message #523138 is a reply to message #520432] Thu, 25 March 2010 05:49 Go to previous message
I still can't download the files but I upgraded my ATL version and can't reproduce the bug anymore. Well I adapted my transformations in consequence when I faced the bug so it's not totally the same tests as before. I'll surely face the problem again soon so I'll study more precisely the circumstances when it happens and report them in this thread.
Previous Topic:[ATL][AML] Obtaining AML plugins
Next Topic:[QVTo] Transforming a relation to a already transformed Element
Current Time: Sat Jul 19 23:07:35 EDT 2025
Powered by FUDForum. Page generated in 0.04174 seconds
