Java/Javascript Bridge and SVG documents [message #521451] |
Wed, 17 March 2010 11:59  |
I am using the Browser widget to display an SVG. The SVG has embedded Javascript that calls Java BrowserFunctions exposed by the Browser widget.
This works fine in RCP, but fails in RAP 1.3 M5 ( I raised a bug here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=306209 )
I'd really like to get a single-sourcing demo of this working for a potential future project. Can anyone suggest where (and how!) I should start debugging this?
Mat
Re: Java/Javascript Bridge and SVG documents [message #521502 is a reply to message #521451] |
Wed, 17 March 2010 15:46   |
Hi Mat,
I've just took a look at your screen-shot attached to the bug. It seems
that the RAP application is starter from localhost (127.0.0.1), but the
page with SVG in the Browser widget is from different domain (
www.matbooth.co.uk). Due to browser security restrictions, it is not
possible to register a javascript function in a page, located in a
different domain than the RAP application. This is a limitation of
BrowserFunction support, but we can't do anything about it - browser
security policies.
Best,
Ivan
> widget.
> Regards,
> Mat
Re: Java/Javascript Bridge and SVG documents [message #521618 is a reply to message #521502] |
Thu, 18 March 2010 06:22  |
Ivan Furnadjiev wrote on Wed, 17 March 2010 15:46:
> Hi Mat,
> security policies.
Aha!
If I serve the document as a static resource using the "org.eclipse.equinox.http.registry.resources" extension point, then it works as expected.
I wasn't aware of this browser restriction, but it seems you are right. Thanks for your help, it's been most useful.
I will close the bug.
Mat
FUDForum. Page generated in 0.06796 seconds
