[ATL] Set boolean flag if object is referenced [message #521429] |
Wed, 17 March 2010 11:07  |
I have been playing around with ATL a little bit and am trying to solve the following:
My input model contains a collection (0...*) of classes and a reference to one of these classes.
My output model contains the same collection, but instead of the reference to one of the classes, every class contains a boolean flag.
What I want is that the transformation sets the boolean flag to "true" in the class that is referenced in the input model.
Any ideas how to accomplish this?
I tried something like the following:
module In2Out;
create OUT : OutModel from IN : InModel;
helper def : isFinishStation(station : InModel!Station) : Boolean =
if (station = self.finishStation) then
true
else
false
endif;
rule Level2Level {
from
s : InModel!Level
to
t : OutModel!Level (
stations <- s.stations
rule Station2Station {
from
s : InModel!Station
to
t : OutModel!Station (
name <- s.name,
isFinishStation <- thisModule.isFinishStation(s)
If I run the transformation then it produces an output model without any errors on the console.
But the boolean flag is never set to true.
Thanks for the help,
Bernhard
Re: [ATL] Set boolean flag if object is referenced [message #521450 is a reply to message #521429] |
Wed, 17 March 2010 11:50   |
Bernhard L. a écrit :
> Hello,
> the following:
> module In2Out;
Here "self" refers to the current station.... (if I'm correct).
You need to refer to the input "model" (or anything else) which have the
reference.
You may try to get "station" container [container] and see its
"finishStation" property ...
> true
> else
> false
> endif;
> rule Level2Level {
> from
> s : InModel!Level
> to
> from
> s : InModel!Station
> to
> name <- s.name,
> Bernhard
Cordialement
Vincent MAHÉ
Ingénieur plate-forme - Cesar/Artemisia - Équipe Espresso
IRISA-INRIA, Campus de Beaulieu, 35042 Rennes cedex, France
Tél: +33 (0) 2 99 84 71 00, Fax: +33 (0) 2 99 84 71 71
FUDForum. Page generated in 0.04576 seconds
