Home » Eclipse Projects » Remote Application Platform (RAP) » Reload Java Class (i.e. a ViewPart) on Runtime
Reload Java Class (i.e. a ViewPart) on Runtime [message #521107] Tue, 16 March 2010 09:44 Go to next message
Hello there
is it possible to reload some Views, Editor, or other Java Classes while running a RAP Application? I wish i.e. to add new functionality to a existing view, so next time the view is reopened on the client side, the new class implementation should be loaded?
Greetings, Edin
Re: Reload Java Class (i.e. a ViewPart) on Runtime [message #521132 is a reply to message #521107] Tue, 16 March 2010 05:50 Go to previous messageGo to next message
Hi Edin,
if I understand your question correctly, you want to change i.e. a
ViewPart Implementation during runtime. Maybe triggered by a user's
interaction. Am I right?
I see no way to do this with Eclipse Techniques. But I think this is
not an eclipse problem. Instead it's more a question on software
design. You may check the proxy design pattern [1] to see how
implementations could change durign runtime. I think this is exactly
what you need.
Feel free to ask if something is not clear.
Regards Holger
[1] http://en.wikipedia.org/wiki/Proxy_pattern
On 2010-03-16 14:44:55 +0100, ededagic <dedagic@acsa-consulting.de> said:
> Hello there
> Greetings, Edin
http://eclipsesource.com
http://twitter.com/eclipsesource
Re: Reload Java Class (i.e. a ViewPart) on Runtime [message #521144 is a reply to message #521132] Tue, 16 March 2010 10:57 Go to previous messageGo to next message
Hey Holger,
thny for your answer, but that is not what i want. Actually i just want to have sth. like dynamically reloading Java classes while the RAP Application is running. I.e. i have a ViewPart with a button and, i start the RAP application with that view. So after a while i check that my view should have two buttons. So i add that second button to the source, create class file, and want to use that new class file instead of old one. but without retarting the RAP app. dynamically loading and reloading class with normal java isnt a problem. but i dont know if its possible with RAP? i want, that when user logs in next time (or in best way, reopen the view), he get that new view instance with two buttons, without restarting the whole RAP app.
hope now its clear, otherwise i can write to you a mail on german if you like.
Greetings, Edin
Re: Reload Java Class (i.e. a ViewPart) on Runtime [message #521157 is a reply to message #521144] Tue, 16 March 2010 11:25 Go to previous messageGo to next message
Oh ok,
so to replace classes you can use OSGi. Just load a new bundle (should
have a newer version than the old one) with your ViewPart Impl and
Extension. Just google a little bit about OSGi/Equinox and how to load
bundles.
Hope this may help.
Regards Holger
On 2010-03-16 15:57:17 +0100, ededagic <dedagic@acsa-consulting.de> said:
> Hey Holger,
> Greetings, Edin
Re: Reload Java Class (i.e. a ViewPart) on Runtime [message #521164 is a reply to message #521157] Tue, 16 March 2010 11:53 Go to previous messageGo to next message
Ok, that with Osgi we are looking now, but its not so comfrotable as wanted. we have some kind of admin viewpart inside our application, and from there we would like to reload some views. with osgi you have to reload projects with more classes. that means that we should have one project per view. we will do it if necessary, but i would prefer the way to reload single classes if possible.
on the other hand, as i undestand reloading new version of osgi bundle works from console. is it possible to do it programatically, and if someone is using that app at the moment of reloading, will he be able to continue working within that session?
Regards, Edin
Re: Reload Java Class (i.e. a ViewPart) on Runtime [message #521936 is a reply to message #521164] Fri, 19 March 2010 07:39 Go to previous message
Hi Edin,
yes, you can start/stop/update/install/remove osgi bundles programmatically. You'll find everything you need in the osgi javadocs. Have a look at the Bundle Interface and the BundleContext Interface.
As far as i know, the current sessions will stay valid.
If you are working with custom widgets that contain their own custom client-side qooxdoo classes, you may run into problems. RAP 1.2 prepares the javascript code for the client at application startup and therefore will not deliver JS-code to the client, which wasn't present at startup.
Onno Hensgen
Previous Topic:Error disposing image resource
Next Topic:Your advice about rap
Current Time: Sat Jul 19 12:03:34 EDT 2025
Powered by FUDForum. Page generated in 0.23881 seconds
