Home » Archived » BIRT » Oracle ALTER SESSION with JavaScript
Oracle ALTER SESSION with JavaScript [message #521101] Tue, 16 March 2010 09:33 Go to next message
We use BIRT for access to Oracle databases.
For some reasons we need to alter session settings for each connection:
ALTER SESSION
SET NLS_DATE_FORMAT =' ...'
NLS_TERRITORY = America
CURSOR_SHARING = SIMILAR
RECYCLEBIN = OFF
As you can see, controlling localization with standard BIRT settings is not sufficient for us.
Our software is based on PHP and thus we use BIRT as it is.
Is it possible to alter oracle session settings using the BIRT
JavaScript interface only (Data set/data source events)?
Any help is appreciated!
Re: Oracle ALTER SESSION with JavaScript [message #521172 is a reply to message #521101] Tue, 16 March 2010 11:48 Go to previous messageGo to next message
Christian,
Can you put this code in a stored procedure and place a hidden table at
the top of the report that calls it?
Jason
Christian Seeling wrote:
> We use BIRT for access to Oracle databases. For some reasons we need to
> ALTER SESSION
> RECYCLEBIN = OFF
Re: Oracle ALTER SESSION with JavaScript [message #521186 is a reply to message #521172] Tue, 16 March 2010 12:56 Go to previous messageGo to next message
Hi Jason,
first of all, thanks for the quick reply!
We like the idea of having a stored procedure in place.
However, how can a BIRT dataset run such a procedure?
Are BIRT datasets capable of SQL EXEC or EXECUTE statements?
Thanks in ad,
Christian
Re: Oracle ALTER SESSION with JavaScript [message #521215 is a reply to message #521186] Tue, 16 March 2010 14:20 Go to previous message
BIRT can call a stored procedure by creating a new dataset and selecting
stored procedure instead of sql query. The syntax for the sp is:
{call procedure-name(arg1,arg2, ...)}
Jason
> Hi Jason,
> Thanks in ad,
> Christian
Previous Topic:Loading reports from Classpath?
Next Topic:BIRT migration to EMF?
Current Time: Sun Jul 20 11:33:02 EDT 2025
Powered by FUDForum. Page generated in 0.25162 seconds
