Error disposing image resource [message #521035] |
Tue, 16 March 2010 05:53  |
I'm trying to display an image as Label background. Everything works fine, but when I dispose the image I get:
java.lang.IllegalStateException: A factory-created resource cannot be disposed.
at org.eclipse.swt.graphics.Resource.dispose(Resource.java:80)
My code to allocate the image is:
ImageDescriptor imgDescr = AbstractUIPlugin .imageDescriptorFromPlugin(Activator.PLUGIN_ID,
"icons/aboutdialogimage.png");
Image img=imgDescr.createImage();
img.dispose(); // Exception here
The javadoc for createImage() explicit states, that every call creates an new image and that the image must be released by calling dispose():
Note: this method differs from createResource(Device) in that the returned image
must be disposed directly, whereas an image obtained from createResource(...)
must be disposed by calling destroyResource(...). It is not possible to
mix-and-match. If you obtained the Image from this method, you must not dispose
it by calling destroyResource. Clients are encouraged to use
create/destroyResource and downcast the result to Image rather than using
createImage.
Any idea ?
Marc
[Updated on: Tue, 16 March 2010 05:54] by Moderator
Re: Error disposing image resource [message #521047 is a reply to message #521035] |
Tue, 16 March 2010 06:22   |
Hi Marc,
this is a known issue. There is already a bug opened to keep track on it:
305136: Images from Descriptor are not disposable
https://bugs.eclipse.org/bugs/show_bug.cgi?id=305136
Best,
Ivan
On 03/16/2010 11:53 AM, Marc42 wrote:
> Hello,
> disposed.
> Image img=imgSescr.createImage();
> returned image
> createResource(...)
> to mix-and-match. If you obtained the Image from this method, you must
> not dispose
> using createImage.
> Any idea ?
> Regards
> Marc
Re: Error disposing image resource [message #521048 is a reply to message #521035] |
Tue, 16 March 2010 06:35  |
by further tracing into this problem I found:
- Image.dispose() is Resource.dispose().
- This throws the exception, if the property 'device' is null, which it seems to be in every case.
I tried calling createImage() with providing a device:
createImage(Display.getCurrent())
Same problem: property 'device' is still null and the exception it thrown.
The Image is somehow cached. I guess that createImage() behaves like createResource().
May be this is a bug ?
Marc
Re: Error disposing image resource [message #521133 is a reply to message #521048] |
Tue, 16 March 2010 05:50  |
Hi Marc,
in RAP there are two "types" of resources:
1. a factory created resources - created by Graphics.getXXX methods.
These resources are shared between the sessions and can't be disposed (
device is null ).
2. and "standard" one - created like: new Image( device, ...). Their
device is not null and you can dispose them as usual.
As I mentioned in my previous post, currently, images created from
ImageDescriptor can't be disposed (see bug 305136 ), because they are
factory created images.
Best,
Ivan
On 03/16/2010 12:35 PM, Marc42 wrote:
> Hello,
> thrown.
> createResource().
> Regards
> Marc
FUDForum. Page generated in 0.03782 seconds
