Tracker won't release on Mouse-up [message #520449] |
Fri, 12 March 2010 07:40  |
I'm having an intermittent problem with Tracker in that 25% of the time it does not release the rubber-band box when I let go of the mouse button. Most of the time this works as it should, but I have not found a pattern or correlation of when it works versus when it doesn't. It appears to be a bug.
The usual and expected behavior is: when I press and hold down Button 1, and move the mouse, the Tracker box follows the mouse. When I release Button 1, the box stops following the mouse movements.
But when this fails, what happens is the Tracker box continues to follow the mouse movements even after I release Button 1 (as if Tracker was unaware that Button 1 has been released). Sometimes, it takes several clicks of Button 1 to cause the Tracker box to let go.
Has anyone else had this problem? Any ideas of what I could do to work around the problem? My code pretty much just mimics the Tracker sample code provided by Eclipse...
thanks for the help!
Mark
Re: Tracker won't release on Mouse-up [message #520518 is a reply to message #520449] |
Fri, 12 March 2010 07:36   |
Hi Mark,
Tracker should be reasonably straight-forward, so as you say, you're
probably seeing a bug. Which platform and SWT version are you using? Do
you see the problem with
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet23. java ?
Grant
"Mark" <Mark.Fenbers@noaa.gov> wrote in message
news:hndcnd$jn5$1@build.eclipse.org...
bug.
> Mark
Re: Tracker won't release on Mouse-up [message #520563 is a reply to message #520518] |
Fri, 12 March 2010 15:12  |
I am not having the same problem with Snippet23. However, I am no longer having the problem with my code either. I am simply not able to repeat the problem today even though other times the problem occurs more than 50% of the time. So there must be some external factors that influence this, say a load on the system, etc.. Perhaps I should wait until the problem occurs again in my code and then try out Snippet23 again to see if it happens there as well...
I don't think this issue simply fixed itself, but rather is not revealing itself today. I'll post again if it does to discuss whether a bug report is needed...
Mark
FUDForum. Page generated in 0.04044 seconds
