Home » Eclipse Projects » Mylyn » password for JUnit test
password for JUnit test [message #520357] Fri, 12 March 2010 00:10 Go to next message
I downloaded the Mylyn source code and tried to run a JUnit test for org.eclipse.mylyn.jira.tests
I followed the instructions on
http://wiki.eclipse.org/index.php/Mylyn/Contributor_Referenc e#JUnit_tests
I created the credentials.properties under org.eclipse.mylyn.context.tests with
user: test@mylyn.eclipse.org
pass:
I got the following error with the password values I tried:
org.eclipse.mylyn.internal.jira.core.service.JiraAuthenticat ionException: Invalid user name or password
Can I ask what is the password here? I don't understand what is the "<project's name lowercase>test" here. Can you give me an example?
Lin
[Updated on: Fri, 12 March 2010 00:11] by Moderator
Re: password for JUnit test [message #520373 is a reply to message #520357] Fri, 12 March 2010 02:12 Go to previous messageGo to next message
You should have the following lines in the credentials.properties:
pass: <project's name lowercase>test
Substitute <project's name lowercase> with mylyn.
Steffen
Raistlin wrote:
> with user: mailto:test@mylyn.eclipse.org
> pass:
> Thanks
> Lin
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: password for JUnit test [message #520468 is a reply to message #520373] Fri, 12 March 2010 09:10 Go to previous messageGo to next message
Hi Steffen,
Thank you very much. I tried with
user: test@org.eclipse.mylyn
pass: mylyntest
Then I got
The first error showed at method testValidate39 of org.eclipse.mylyn.jira.tests.core.JiraClientFactoryTest
Any idea? Thanks.
Lin
Re: password for JUnit test [message #520526 is a reply to message #520468] Fri, 12 March 2010 12:50 Go to previous message
sorry, the username had a typo. It needs to be tests and not test:
user: tests@org.eclipse.mylyn
The password looks rights.
Steffen
> Hi Steffen,
> pass: mylyntest
> Then I got
> Any idea? Thanks.
> Lin
Steffen Pingel
Re: password for JUnit test [message #600926 is a reply to message #520373] Fri, 12 March 2010 09:10 Go to previous message
Hi Steffen,
user: mailto:test@org.eclipse.mylyn
pass: mylyntest
Then I got
Any idea? Thanks.
Lin
Re: password for JUnit test [message #600931 is a reply to message #600926] Fri, 12 March 2010 12:50 Go to previous message
Steffen
> Hi Steffen,
> pass: mylyntest
> Then I got
> Any idea? Thanks.
> Lin
Steffen Pingel
Previous Topic:Eclipse freezes while "loading org.eclipse.mylyn.tasks.ui"
Next Topic:open attachemtn with default editor?
Current Time: Sun Jul 20 06:18:46 EDT 2025
Powered by FUDForum. Page generated in 0.04520 seconds
