Home » Eclipse Projects » DTP » Postgres jdbc3 or jdbc4 driver support?(Database Connection wizard expects jdbc2 driver)
Postgres jdbc3 or jdbc4 driver support? [message #509319] Thu, 21 January 2010 18:16 Go to next message
Postgres 8.4 requires jdbc3 or jdbc4 driver, but the database connection wizard in dtp seems to require the jdbc2 driver. Is this a known limitation or am I doing something wrong?
Following occurs trying to use jdbc4 driver in Galileo on Windows:
java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:124)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:260)
at java.net.URLClassLoader.access$100(URLClassLoader.java:56)
at java.net.URLClassLoader$1.run(URLClassLoader.java:195)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at java.net.FactoryURLClassLoader.loadClass(URLClassLoader.java :579)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at org.eclipse.datatools.enablement.internal.postgresql.Postgre SQLJDBCConnection.createConnection(PostgreSQLJDBCConnection. java:86)
at org.eclipse.datatools.connectivity.DriverConnectionBase.inte rnalCreateConnection(DriverConnectionBase.java:104)
at org.eclipse.datatools.connectivity.DriverConnectionBase.open (DriverConnectionBase.java:53)
at org.eclipse.datatools.enablement.internal.postgresql.Postgre SQLJDBCConnection. <init>(PostgreSQLJDBCConnection.java:47)
at org.eclipse.datatools.enablement.internal.postgresql.Postgre SQLConnectionFactory.createConnection(PostgreSQLConnectionFa ctory.java:51)
at org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:83 )
at org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:355)
at org.eclipse.datatools.connectivity.ui.PingJob.createTestConn ection(PingJob.java:76)
at org.eclipse.datatools.connectivity.ui.PingJob.run(PingJob.ja va:59)
Re: Postgres jdbc3 or jdbc4 driver support? [message #510184 is a reply to message #509319] Tue, 26 January 2010 10:58 Go to previous messageGo to next message
Unfortunately we don't have any Postgres-specific knowledge on the team
any more. We'd love to have someone with Postgres know-how take a look
and contribute patches for anything they find though...
> r.java:124)
> at java.security.AccessController.doPrivileged(Native Method)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: Postgres jdbc3 or jdbc4 driver support? [message #520482 is a reply to message #509319] Fri, 12 March 2010 09:35 Go to previous message
This means normalls that you JVM is too old and that the *.jar/*.clas requires a
newer JVM.
TheWolf
Previous Topic:Access to Connection Profiles
Next Topic:Postgres jdbc3 or jdbc4 driver support?
Current Time: Sat Jul 19 15:16:04 EDT 2025
Powered by FUDForum. Page generated in 0.05680 seconds
