Home » Archived » eBAM » How do the Adapters work?
How do the Adapters work? [message #520312] Thu, 11 March 2010 16:40 Go to next message
This looks very interesting.
- Are they directly deployed on each remote system and communicating with a server? (like agents for Zabbix and plugins for Nagios)
- Are they system-specific?
- Can new adapters be easily developed?
Sven
Re: How do the Adapters work? [message #520624 is a reply to message #520312] Sat, 13 March 2010 08:16 Go to previous message
-The adapters are components with the same interface, they are managed by the Adapter Manager.
Regards the comunication aspects depends from the Adapter you are using, for example the JMS Adapter reads messages from a queue, or if you are using File Adapter you can use the "Agent Control" ( TPTP Project ) to read information from remote server.
-The adapters are platform independent
- eBAM is very easy to extend, if you have to write a custom Adapter you can follow these steps:
i) write the Adapter (it's a java class), that implements a specific interface and contains the code to bring information from external system
ii) configure the adapter manager in order to start up your new Adapter.
Angelo
Previous Topic:In a real case
Next Topic:How do the Adapters work?
Current Time: Sat Jul 19 11:46:59 EDT 2025
Powered by FUDForum. Page generated in 0.03124 seconds
