Home » Language IDEs » Java Development Tools (JDT) » CVS History problem
icon5.gif  CVS History problem [message #511076] Fri, 29 January 2010 12:52 Go to next message
I'm having trouble viewing the history of any of my files in a CVS project. In short, I can't see it at all. Whenever I try to do a compare to history or view history, it brings up the history pane, but it's blank. I've tried a number of things, none of which have helped.
Thanks in advance Smile
[Updated on: Tue, 02 February 2010 16:00] by Moderator
Re: CVS History problem [message #512206 is a reply to message #511076] Thu, 04 February 2010 07:07 Go to previous messageGo to next message
I confirm the same problem. The strange thing is that if I recreate the workspace, cvs repository, import the project, then the show history works for a while, but after a period the problem reappears.
Eclipse Galileo on Ubuntu 9.10
Re: CVS History problem [message #520248 is a reply to message #511076] Thu, 11 March 2010 11:53 Go to previous messageGo to next message
A co-worker of mine has the same problem. He's using Ubunt 9.10, too.
Anyone has any news on this?
Mauro.
Re: CVS History problem [message #522679 is a reply to message #520248] Tue, 23 March 2010 11:12 Go to previous messageGo to next message
I've the same problem.
Ubuntu 9.10 & eclipse Build id: 20100218-1602
Any ideas ?
Thanks a lot,
Sergio.
Re: CVS History problem [message #522845 is a reply to message #522679] Tue, 23 March 2010 23:26 Go to previous messageGo to next message
> Any ideas ?
When i have this, i click on "Link with editor", and then i press on the
refresh button.
HTH
Re: CVS History problem [message #522872 is a reply to message #522845] Wed, 24 March 2010 05:45 Go to previous messageGo to next message
> refresh button.
"Link with editor" does not appear in the view. It's totally blank. If
you expand and then restore the History view, you see it has drawing
problems.
Mauro.
Re: CVS History problem [message #532330 is a reply to message #511076] Sat, 08 May 2010 06:37 Go to previous messageGo to next message
Can confirm this problem with Lucid Lynx fresh install and then installing eclipse through Ubuntu Software Center. Also was happening on Koala. Both local history and cvs history aren't visible even if linked with with the editor or right clicking -> Team -> Show History.
But if you download Eclipse from the web and install it the view history does work.
Sheamus
[Updated on: Sat, 08 May 2010 06:39] by Moderator
Re: CVS History problem [message #532464 is a reply to message #532330] Mon, 10 May 2010 03:30 Go to previous messageGo to next message
Il 08/05/2010 12.38, sheamus ha scritto:
> But if you download Eclipse from the web and install it the cvs plugin
> does work.
My co-worker switched from Ubuntu 9.10 to Debian Lenny and still has
this problem, even though he is using Eclipse downloaded from
Eclipse.org (and not installed through apt-get or such).
Therefore, the problem may be in GTK.
Mauro.
Re: CVS History problem [message #534428 is a reply to message #532464] Wed, 19 May 2010 03:33 Go to previous messageGo to next message
Just had the same problem (Galileo/Ubuntu 9.10)
I don't know how it happens but deleting the cvs dialog settings
(workspace/.metadata/.plugins/org.eclipse.team.cvs.ui/dialog _settings.xml) fixed the problem
[Updated on: Wed, 19 May 2010 03:34] by Moderator
Re: CVS History problem [message #534429 is a reply to message #511076] Wed, 19 May 2010 03:37 Go to previous messageGo to next message
Thank you so much! Removing that file fixed it!
Re: CVS History problem [message #534441 is a reply to message #534429] Wed, 19 May 2010 04:35 Go to previous messageGo to next message
I just opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=313480 to track the problem.
Mariot
Re: CVS History problem [message #540104 is a reply to message #534441] Mon, 14 June 2010 18:15 Go to previous messageGo to next message
I can confirm that deleting the XML file fixed the problem. I am running eclipse 3.5.0 under Ubuntu 10.04.
Thanks for the post!
Re: CVS History problem [message #540296 is a reply to message #511076] Tue, 15 June 2010 10:44 Go to previous message
I was having this same issue on Fedora 13, and removing that file worked for me as well. Thanks so much.
Previous Topic:how to add a jar file plugin dependency in rcp project
Next Topic:application runs after export ONLY !
Current Time: Sun Jul 20 02:28:59 EDT 2025
Powered by FUDForum. Page generated in 0.09065 seconds
