Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] DefaultMerger and dangling references...
[EMF Compare] DefaultMerger and dangling references... [message #519935] Wed, 10 March 2010 04:46 Go to next message
Originally posted by: mail.andreasscharf.com
while I was stepping through the DefaultMerger I got a bit confused
about the method removeDanglingReferences(EObject deletedObject). Am I
wrong or does this method delete arbitrary crossreferences from either
the root, resource or resourceSet? Because there are other resources
contained in the same resourceSet as the compare stuff, I noticed that
this code tried to delete some objects which doesn't have anything to
do with the deleted object.
Can you confirm this behavior?
Andreas
Re: [EMF Compare] DefaultMerger and dangling references... [message #520127 is a reply to message #519935] Thu, 11 March 2010 04:13 Go to previous message
--------------040604010608090706040401
Andreas,
This method is meant to delete all references still pointing towards the
deleted EObject, and it will indeed look in all resources contained in
the same resourceSet as the deleted object's resource.
That said, that code is pretty generic and deletes all references to
objects that are no longer contained in a resource (which is the result
of using EcoreUtil.remove()). It is possible that we remove objects with
no relation to the deleted element, yet it should be elements that have
no longer reason to be referenced. Do you have an example of us removing
important references?
Laurent Goubet
Obeo
Andreas Scharf wrote:
> this code tried to delete some objects which doesn't have anything to do
> Best regards,
> Andreas
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------040604010608090706040401--
Previous Topic:EMFT Texo: generating true java pojos from ecore/xsd, with runtime model support, XMI/XML (de-)seria
Next Topic:[EMF Compare] DefaultMerger and dangling references...
Current Time: Sat Jul 19 14:03:29 EDT 2025
Powered by FUDForum. Page generated in 0.03809 seconds
