Home » Eclipse Projects » Remote Application Platform (RAP) » It seems a Bug when calling "WorkbenchPage.resetPerspective"
It seems a Bug when calling "WorkbenchPage.resetPerspective" [message #520081] Thu, 11 March 2010 01:02 Go to next message
My Env: Eclipse 3.5 RAP 1.3M4
Please consider this scenario: custom define PresentationFactory, don't show CoolBar in ApplicationWorkbenchWindowAdvisor
In this case, when calling resetPerspective, as per the code in WorkbenchPage.resetPerspective()
public void resetPerspective() {
// Run op in busy cursor.
// Use set redraw to eliminate the "flash" that can occur in the
// coolbar as the perspective is reset.
ICoolBarManager2 mgr = (ICoolBarManager2) window.getCoolBarManager2();
try {
mgr.getControl2().setRedraw(false);
BusyIndicator.showWhile(null, new Runnable() {
public void run() {
busyResetPerspective();
} finally {
mgr.getControl2().setRedraw(true);
mgr.getControl2() will be null because we setShowCoolBar(false);
Then an exception will be throw.
Isn't is a bug?
Re: It seems a Bug when calling "WorkbenchPage.resetPerspective" [message #520115 is a reply to message #520081] Wed, 10 March 2010 22:54 Go to previous messageGo to next message
Hi Wayne,
have you tried the same code in RCP? The rule of thumb is: if it works
in RCP, but fails in RAP, then it's likely to be a bug in RAP.
Did you change the workbench layout by overriding
ApplicationWorkbenchAdvisor#createWindowContents? I remember that it's
easy to screw things up there....
Ralf
> try {
> public void run() {
> } finally {
> mgr.getControl2() will be null because we setShowCoolBar(false); Then an
> Isn't is a bug?
Re: It seems a Bug when calling "WorkbenchPage.resetPerspective" [message #520134 is a reply to message #520115] Thu, 11 March 2010 04:29 Go to previous messageGo to next message
Hi Ralf,
Because I am working on a very big project, so it's very hard for me to change my project now to RCP.
But i think it might be a easy way to reproduce it if you have the first example of RAP on website (I think you have Razz ). The link is:
http://www.eclipse.org/rap/demos.php
In it, there is a customer-defined presentation factory, you only need to add a editor, and NOT show the CoolBar. Then if you open the editor and close it AND in editor's dispose method call that reset method, then the Exception will be thrown.
I didn't change the workbench layout.
Re: It seems a Bug when calling "WorkbenchPage.resetPerspective" [message #520151 is a reply to message #520134] Thu, 11 March 2010 06:07 Go to previous messageGo to next message
This is a RCP issue.
You would have to do something like this:
public void preWindowOpen() {
super.preWindowOpen();
IWorkbenchWindowConfigurer configurer = getWindowConfigurer();
configurer.setShowCoolBar( true );
public void postWindowCreate() {
super.postWindowCreate();
((WorkbenchWindow) getWindowConfigurer().getWindow()).toggleToolbarVisibility() ;
The same is valid for the perspective bar...
Re: It seems a Bug when calling "WorkbenchPage.resetPerspective" [message #520157 is a reply to message #520151] Thu, 11 March 2010 06:39 Go to previous message
Actually I am not quite sure about that.
But just from the simple logic, I guess. if we don't show CoolBar, then the CoolBar will not create its Control2, when getting Control2.xxxx() will throw an Exception.
And when I use default Presentation Factory, I found that it does create a Control2, so it works.
Maybe we could refer to the implementation of default Presentation Factory.
Previous Topic:Icons initially not visible in perspective
Next Topic:Could someone check the RAP example, I guess there might be an error
Current Time: Sun Jul 20 11:09:21 EDT 2025
Powered by FUDForum. Page generated in 0.05164 seconds
