Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Once again: Drop email from Outlook
Once again: Drop email from Outlook [message #518149] Wed, 03 March 2010 04:30 Go to next message
Hi I searched the forums for this topic and it seems I'm not the only one who tries to do that. I found
http://www.eclipse.org/forums/index.php?t=msg&&th=14 7516&goto=464661
and have no clue about the native things going on there. I wonder what I have to return in getTypeIds and getTypeNames for such a Transfer Type. Can anyone help me out with this ? I guess there must be implementations and I do not want to reinvent.
Regards Thomas
Re: Once again: Drop email from Outlook [message #519397 is a reply to message #518149] Mon, 08 March 2010 12:34 Go to previous messageGo to next message
For getTypeIds() the magical number on my machine for a dragged Outlook news message is 49588. I found this by putting a breakpoint in the custom Transfer class' getTypeIds() implementation, and seeing which type id its caller (ByteArrayTransfer.isSupportedType()) was looking for. This type id remained consistent for me across many runs, though I don't know if it would be the same on another machine or not.
When the nativeToJava() implementation from the old post that you linked to was invoked, for me it gave stg's tymed as TYMED_HGLOBAL rather than the post's expected TYMED_ISTORAGE. So to handle the TYMED_HGLOBAL case a block is needed in nativeToJava() like:
if ((stg.tymed & COM.TYMED_HGLOBAL) != 0) {
int /*long*/ hMem = stg.unionField;
int size = OS.GlobalSize(hMem);
byte[] buffer = new byte[size];
int /*long*/ ptr = OS.GlobalLock(hMem);
OS.MoveMemory(buffer, ptr, size);
OS.GlobalUnlock(hMem);
OS.GlobalFree(hMem);
if (stg.pUnkForRelease == 0) {
OS.GlobalFree(stg.unionField);
return buffer;
The only thing I'm not sure about is what to do with the bytes (buffer). I don't know what the format is of the data being provided by Outlook. I tried to change it to a String in a similar manner to what TextTransfer does, but this doesn't give a readable result. Maybe this transfer type has a shape to it that needs to be parsed out, you'll need to look into this.
Sorry that this isn't a complete solution. If you find something that's helpful (eg.- if this transfer type has a published shape), then feel free to post a follow-up here with the link.
Grant
Re: Once again: Drop email from Outlook [message #519580 is a reply to message #519397] Tue, 09 March 2010 06:26 Go to previous messageGo to next message
I found that if I drop an email (thats what I want to do) the number is
49852. But in
STGMEDIUM stg = new STGMEDIUM();
stg.tymed = -1;
int hresult = idata.GetData(formatetc, stg);
i don't get an ok but something like -27xxx. (Its actually an COM.E_FAIL Sorry but I have completely no understanding of these windows thingys Smile
Can anyone help me out ?
[Updated on: Tue, 09 March 2010 07:27] by Moderator
Re: Once again: Drop email from Outlook [message #519664 is a reply to message #519580] Tue, 09 March 2010 05:56 Go to previous messageGo to next message
I don't know what would cause this.
http://msdn.microsoft.com/en-us/library/ms678431(VS.85).aspx indicates that
the error values that the GetData() invocation can return are:
DV_E_LINDEX = 0x80040068,
DV_E_FORMATETC = 0x80040064,
DV_E_TYMED = 0x80040069,
DV_E_DVASPECT = -2147221397,
E_INVALIDARG = 0x80070057,
E_UNEXPECTED = 0x8000FFFF,
OLE_E_NOTRUNNING = 0x80040005,
E_OUTOFMEMORY = 0x8007000E;
STG_E_MEDIUMFULL = 0x80030070;
I just grabbed the hex values above from some random code on-line, but
presumably they're correct. Hopefully determing what the error is will
provide a clue regarding what is needed (keep in mind at all of the values
above that are of form 0x800... will roll around to be int values
like -214... ).
Grant
"Thomas Kratz" <eiswind@googlemail.com> wrote in message
news:hn5b8n$qqt$1@build.eclipse.org...
> 49852. But in
> stg.tymed = -1;
> i don't get an ok but something like -27xxx. Sorry but I have completely
no understanding of these windows thingys :)
Re: Once again: Drop email from Outlook [message #519665 is a reply to message #519664] Tue, 09 March 2010 11:05 Go to previous messageGo to next message
The Error Code I get stands for E_FAIL which means something like unknown error. I can get the text out of it (which is the header only) but not the content. I guess i have to set the correct aspect, but once again I have searched google for more than an hour witout proper results. the c# examples use DataFormat Constants that I cannot see.
Re: Once again: Drop email from Outlook [message #519676 is a reply to message #519665] Tue, 09 March 2010 11:45 Go to previous messageGo to next message
I found
http://www.codeproject.com/KB/office/outlook_drag_drop_in_cs .aspx
but I cannot translate that to swt-java-com Sad
Re: Once again: Drop email from Outlook [message #520280 is a reply to message #519676] Thu, 11 March 2010 14:42 Go to previous message
I finally made some progress on this.
You can read it on
http://thomaskratz.blogspot.com/2010/03/swt-drop-outlook-ema il.html
Previous Topic:SWT: Dependencies of Feature Project
Next Topic:Tracker won't release on Mouse-up
Current Time: Sun Jul 20 10:53:17 EDT 2025
Powered by FUDForum. Page generated in 0.04126 seconds
