Home » Archived » IAM (Eclipse Integration for Apache Maven) » File org.eclipse.wst.common.component modified
File org.eclipse.wst.common.component modified [message #516762] Wed, 24 February 2010 20:44 Go to next message
Since i've upgraded to 0.11, the file "org.eclipse.wst.common.component" is modified each time I clean a web project.
Each time the folowing line is added to the file :
<wb-resource deploy-path="/WEB-INF/classes" source-path="/target/classes"/>
So after a couple of days, I end up with a file like that :
<project-modules id="moduleCoreId" project-version="1.5.0">
<wb-module deploy-name="TSPBnC">
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/Util/Util">
<dependency-type>uses</dependency-type>
</dependent-module>
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/AccesTSP/AccesTSP">
</dependent-module>
<dependent-module deploy-path="/WEB-INF/lib" handle="module:/resource/AccesGPS/AccesGPS">
</dependent-module>
<property name="context-root" value="TSPBnC"/>
<wb-resource deploy-path="/" source-path="src/main/webapp"/>
<property name="java-output-path" value="/target/classes"/>
<wb-resource deploy-path="/WEB-INF/classes" source-path="src/main/java"/>
<wb-resource deploy-path="/WEB-INF/classes" source-path="src/main/resources"/>
</wb-module>
</project-modules>
Does anyone have the same behavior?
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #517041 is a reply to message #516762] Thu, 25 February 2010 16:04 Go to previous messageGo to next message
I noticed that too and fixed it already in the last 0.12 development build.
If you want to try the new build, it's available at
http://q4e.googlecode.com/svn/trunk/updatesite-dev/
http://code.google.com/p/q4e/wiki/Installation
> </dependent-module>
> </dependent-module>
> </dependent-module>
> </wb-module>
> </project-modules>
> Regards,
> Gabriel.
Re: File org.eclipse.wst.common.component modified [message #517772 is a reply to message #517041] Mon, 01 March 2010 19:17 Go to previous messageGo to next message
mmm, really? I tested it and worked. The file doesn't grow anymore,
lines added previously dont get deleted though, but you can delete all
but one by hand, or delete the eclipse config and reimport the project
On 3/1/10 1:58 PM, glandon@piti.pf wrote:
> Hi Carlos,
> I've tried with the latest version from
> http://q4e.googlecode.com/svn/trunk/updatesite-dev/ :
> Eclipse IAM *0.12.0.201002111708* org.eclipse.iam.feature.feature.group
> And I still have this problem.
> Regards,
> Gabriel LANDON
> /Pacifique Informatique et Télécommunications autour d'Internet/
> Tél : 45 43 82 / Fax : 45 43 82 / Mobile : 28 82 62
> Site : _www.piti.pf/_ <http://www.piti.pf/> - Mail : _info@piti.pf_
> <mailto:info@piti.pf>
> De : Carlos Sanchez <csanchez@exist.com>
> A : Gabriel LANDON <glandon@piti.pf>
> Date : 25/02/2010 11:16
> Objet : Re: File org.eclipsewst.common.component modified
build.
> > <?xml version="1.0" encoding="UTF-8"?>
> > </dependent-module>
> > </dependent-module>
> > </dependent-module>
> > </wb-module>
> > </project-modules>
> > Regards,
> > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #518693 is a reply to message #517772] Thu, 04 March 2010 09:04 Go to previous messageGo to next message
Eclipse config is
..project
..classpath
..settings (directory)
Yes, I have 201002111708 installed
On 3/4/10 10:35 AM, glandon@piti.pf wrote:
> Hi Carlos,
> What do you mean with "delete eclipse" config?
> Which directories or files shall I delete?
> I've tried with a fresh eclipse galileo SR2 and I still have the problem.
> Are you using : Eclipse IAM *0.12.0.201002111708* ?
> Regards,
> Gabriel LANDON
> A :
> Cc : Gabriel LANDON <glandon@piti.pf>
> Date : 01/03/2010 14:21
> > Hi Carlos,
> > Regards,
> > Gabriel LANDON
> build.
> > > </dependent-module>
> > > </dependent-module>
> > > </dependent-module>
> > > </wb-module>
> > > </project-modules>
> > > Regards,
> > > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #518719 is a reply to message #518693] Thu, 04 March 2010 14:46 Go to previous messageGo to next message
I've reinstalled a fresh eclipse galileo SR2 with IAM 0.12
I've deleted the project setting files you told me to delete.
I've reimported my project.
And still I have the org.eclipse.wst.common.component which is modifed each time I'm doing a refresh.
Is there a way to rollback to 0.11?
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #518799 is a reply to message #518719] Thu, 04 March 2010 18:18 Go to previous messageGo to next message
in the Install menu just uncheck "show only the latest versions..." and
"hide items that are already installed"
then you can choose any version from the IAM update site or the IAM-dev site
I'll take a look to the issue and keep you posted.
> Regards,
> Gabriel.
Re: File org.eclipse.wst.common.component modified [message #519458 is a reply to message #518799] Mon, 08 March 2010 16:31 Go to previous messageGo to next message
Sorry to bother you again Carlos, but only versions 0.9 and 0.11 are available at http://q4e.googlecode.com/svn/trunk/updatesite-iam/ and only 0.12 is available in http://q4e.googlecode.com/svn/trunk/updatesite-dev/
Is it the site.xml that is not correct as the file of the 0.10 seems to be there?
Also why the maven version is still 2.1 (org.apache.maven.feature_2.1.0.659801e.jar) ?
Will it be possible to have the 2.2.1 soon?
Thank you for your help.
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #520320 is a reply to message #519458] Thu, 11 March 2010 16:56 Go to previous messageGo to next message
I was taking a look and although it's there I was unable to make it show
up in in the update site. Give me a couple of days and will get the
update site fixed.
> be there?
> Gabriel.
Re: File org.eclipse.wst.common.component modified [message #536582 is a reply to message #520320] Fri, 28 May 2010 14:57 Go to previous messageGo to next message
Carlos,
I've rollback to 0.10 and now everything works fine.
So I guess I will stick to 0.10 until a stable 0.12 is released.
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572465 is a reply to message #517041] Mon, 01 March 2010 19:17 Go to previous messageGo to next message
> Hi Carlos,
> Regards,
> Gabriel LANDON
build.
> > </dependent-module>
> > </dependent-module>
> > </dependent-module>
> > </wb-module>
> > </project-modules>
> > Regards,
> > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572513 is a reply to message #517772] Thu, 04 March 2010 13:57 Go to previous messageGo to next message
Eclipse config is
..project
..classpath
> Hi Carlos,
> Regards,
> Gabriel LANDON
> A :
> > Hi Carlos,
> > Regards,
> > Gabriel LANDON
> build.
> > > </dependent-module>
> > > </dependent-module>
> > > </dependent-module>
> > > </wb-module>
> > > </project-modules>
> > > Regards,
> > > Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572596 is a reply to message #572513] Thu, 04 March 2010 14:46 Go to previous messageGo to next message
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572657 is a reply to message #518719] Thu, 04 March 2010 23:13 Go to previous messageGo to next message
> Regards,
> Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572699 is a reply to message #572657] Mon, 08 March 2010 16:31 Go to previous messageGo to next message
Gabriel.
Re: File org.eclipse.wst.common.component modified [message #572712 is a reply to message #572699] Thu, 11 March 2010 16:56 Go to previous messageGo to next message
update site fixed.
> be there?
> Gabriel.
Re: File org.eclipse.wst.common.component modified [message #573159 is a reply to message #520320] Fri, 28 May 2010 14:57 Go to previous message
Carlos,
Gabriel.
Previous Topic:Eclipse IAM at Eclipse Marketplace
Next Topic:Fail using IAM with Eclipse Galileo
Current Time: Sun Jul 20 04:18:47 EDT 2025
Powered by FUDForum. Page generated in 0.08782 seconds
