Home » Archived » BIRT » How to auto-refresh a report?(.. HTML)
How to auto-refresh a report? [message #518770] Thu, 04 March 2010 18:06 Go to next message
I have a table-based report and I wish the HTML version's page to automatically refresh every X seconds. How can I do this?
i tried putting the following in a text element at the top of my report but it doesn't work, I think I have to put it someplace else or use Javascript somewhere:
<meta http-equiv="refresh" content="60" >
I am using BIRT 2.2.1.
Thanks!
Re: How to auto-refresh a report? [message #519065 is a reply to message #518770] Fri, 05 March 2010 13:26 Go to previous messageGo to next message
Lawrence,
I do not remember if this works in 2.2.1 but it works in the latest
versions of BIRT. Add a text element set the type to html and enter a
value similar to the following.
<form name="input" onSubmit="return reloadPage();">
<script type="text/javascript">
function reloadPage() {
//alert("Reload time");
var temp = new String(location.href);
var targetURL = new String();
if(temp.indexOf("__overwrite=") != -1 ){
targetURL = temp.substring(0, temp.indexOf("&__overwrite") -1);
}else{
targetURL = temp;
targetURL += "&__overwrite=true";
//alert( targetURL );
location.replace(targetURL);
return false;
timer=setTimeout('reloadPage()', 5000);
</script>
</form>
Jason
> Thanks!
Re: How to auto-refresh a report? [message #521175 is a reply to message #519065] Tue, 16 March 2010 12:17 Go to previous messageGo to next message
Jason, this works great in 2.2.1 -- once again THANK YOU !
Re: How to auto-refresh a report? [message #531198 is a reply to message #518770] Tue, 04 May 2010 03:38 Go to previous messageGo to next message
In case it's useful to anyone, I am posing the actual, shortened version I used which works ok in 2.2.1. Basically,I removed the "overwrite" section from Jason's example above -- and it seems to work fine. Is there any specific reason for the overwrite section?
var targetURL = new String(location.href);
return false;
timer=setTimeout('reloadPage()', 60000);
</script>
</form>
[Updated on: Tue, 04 May 2010 03:39] by Moderator
Re: How to auto-refresh a report? [message #531323 is a reply to message #531198] Tue, 04 May 2010 10:33 Go to previous messageGo to next message
The overwrite section causes the report to re-execute producing an
updated rptdocument. Without it changes in source data may not be
picked up.
Jason
> I used which works ok in 2.2.2. Basically,I removed the "overwrite"
> return false;
> </script>
> </form>
Re: How to auto-refresh a report? [message #531395 is a reply to message #518770] Tue, 04 May 2010 13:42 Go to previous messageGo to next message
Jason,
Ok, I get it, sorry for butchering your code. I put it back as you originally stated, and remembered why I took out the overwrite section: for a report that has a required parameter, it re-prompts me for that parameter(s). So now I can't figure out how to refresh the report with the same parameter(s) as it was originally run with, while keeping the "overwrite" parameter section.
Re: How to auto-refresh a report? [message #531420 is a reply to message #531395] Tue, 04 May 2010 15:55 Go to previous messageGo to next message
Are you putting the parameter values in the url?
On 5/4/2010 1:42 PM, Lawrence Gaalswyk wrote:
> Jason,
Re: How to auto-refresh a report? [message #531425 is a reply to message #518770] Tue, 04 May 2010 16:42 Go to previous messageGo to next message
Yes I am putting parameters in the URL. Also, I need this to work both for some reports which do have parameters in the URL, and also for some other reports which have no parameters. Maybe that means 2 different scripts I think.
Thank you again for any further advice.
Re: How to auto-refresh a report? [message #531687 is a reply to message #531425] Wed, 05 May 2010 14:26 Go to previous messageGo to next message
Can you post the script/report you are using? If the parameters are in
the URL the parameter box should not be prompting.
Jason
> scripts I think.
Re: How to auto-refresh a report? [message #1773147 is a reply to message #519065] Fri, 22 September 2017 04:17 Go to previous message
Hi Jason
I used the code provided by in my report with refresh interval as 30sec,
Every 30 sec page is getting refreshed but the data updated at back end is not reflecting.
I have used complete javascript code with overwrite option.
Also once i execute the report from BIRT tool it will open the report with dateTime at the left end of window and this dateTime value also not getting updated with page refresh.
I am using Birt
Actuate BIRT Designer Professional
Version: 4.4.0
Build id: v20150710
Thank you
Tejas
Previous Topic:Parameter wildcard value
Next Topic:Birt 4.6 intergration with Wildfly 10.1.0
Current Time: Sun Jul 20 08:05:32 EDT 2025
Powered by FUDForum. Page generated in 0.03983 seconds
