Home » Archived » BIRT » Java and beforeOpen: stop birt execution
Java and beforeOpen: stop birt execution [message #517958] |
Tue, 02 March 2010 05:40  |
how can I stop birt from continuing its execution in a beforeOpen method?
What command should be called (if any)?
public void beforeOpen(IDataSourceInstance dataSource, IReportContext
reportContext) throws ScriptException {
if (hasPermission(reportContext)) {
// show report
super.beforeOpen(dataSource, reportContext);
} else {
// Stop BIRT from continuing
thank you
Nicola
Re: Java and beforeOpen: stop birt execution [message #531518 is a reply to message #518014] |
Wed, 05 May 2010 06:02   |
is there a way to drop the source before doing any query?
I have my datasource defined in a library.
I named it and try the code you suggested, but with no results.
Am I wrong or there's a problem with dropping a datasource defined in a
library?
Thank you,
Nicola
Jason Weathersby ha scritto:
> Nicola,
> In script it would be something like:
> reportContext.getDesignHandle().findElement("mytable").drop();
> Just name the table "mytable" in its general properties. You could then
> add a label that says "You do not have permission to view this report".
> and drop it if they do have permission.
> Jason
> nicola wrote:
>> Hi,
>> thank you for the reply.
>> Is there an example of code?
>> Regards,
>> Nicola
>>> Nicola,
>>> Another approach would be to do this in the beforeFactory and just drop
>>> the report items. Then you could display a message to the user with a
>>> BIRT label report item.
>>> Jason
>>> nicola wrote:
>>>> Hi,
>>>> method?
>>>> @Override
>>>> // show report
>>>> } else {
>>>> thank you
>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #531691 is a reply to message #531518] |
Wed, 05 May 2010 15:07   |
I assume you named it in the library. If your script is in the report
it does not have access to the name. So do something like:
//Get the first datasource and drop it
reportContext.getDesignHandle().getDataSources().get(0).drop ();
Jason
On 5/5/2010 6:02 AM, nicola wrote:
> library?
> Thank you,
> Nicola
>> Nicola,
>> Jason
>> nicola wrote:
>>> Hi,
>>> Regards,
>>> Nicola
>>>> Nicola,
>>>> Jason
>>>> nicola wrote:
>>>>> Hi,
>>>>> method?
>>>>> @Override
>>>>> // show report
>>>>> } else {
>>>>> thank you
>>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #538265 is a reply to message #531691] |
Mon, 07 June 2010 03:20   |
Hi Jason,
this solution does not work.
Nothing happens and the report is shown.
Nicola
> Jason
>> Hi,
>> library?
>> Thank you,
>> Nicola
>>> Nicola,
>>> report".
>>> Jason
>>> nicola wrote:
>>>> Hi,
>>>> Regards,
>>>> Nicola
>>>>> Nicola,
>>>>> drop
>>>>> Jason
>>>>> nicola wrote:
>>>>>> Hi,
>>>>>> method?
>>>>>> @Override
>>>>>> // show report
>>>>>> } else {
>>>>>> thank you
>>>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #538399 is a reply to message #538265] |
Mon, 07 June 2010 10:47   |
You may need to change the index number (ie get(0) to get(1)) depending
on what datasource it is. You also may need to drop the dataset.
Jason
On 6/7/2010 3:20 AM, nicola wrote:
> Hi Jason,
> Regards,
> Nicola
>> Jason
>>> Hi,
>>> library?
>>> Thank you,
>>> Nicola
>>>> Nicola,
>>>> report".
>>>> Jason
>>>> nicola wrote:
>>>>> Hi,
>>>>> Regards,
>>>>> Nicola
>>>>>> Nicola,
>>>>>> drop
>>>>>> Jason
>>>>>> nicola wrote:
>>>>>>> Hi,
>>>>>>> method?
>>>>>>> @Override
>>>>>>> // show report
>>>>>>> } else {
>>>>>>> thank you
>>>>>>> Nicola
Current Time: Sun Jul 20 01:58:30 EDT 2025
Powered by FUDForum. Page generated in 0.06453 seconds
