Home » Eclipse Projects » Eclipse Platform » Showing a subset of table columns questions
Showing a subset of table columns questions [message #517674] Mon, 01 March 2010 11:22
I have a table with n columns, where n<30. Obviously it is hard to display all the columns on the screen with readable information. So the solution is to group the columns and display only a subset of them.
I want to create a menu like this:
Columns
Column set 1
Column set 2
Manage Column Sets
When the user selects the manage menu option a dialog will open allowing the user to add/edit/remove/rename column sets.
When the user add a new column set then the menu will contain the newly added column set.
Questions:
1. As far as I know the menu contribution will have to be a class extending the CompoundContributionItem in order to be reevaluated each time the menu is created. Is this correct or I can just extend the ContributionItem class?
2. How can I make the existing column sets persistent(available when the application is restarted)? If a set a number code for each column how can I remember an array of integers in a preference store (a single integer can be stored ... but not an array of integers)? Is there any other mechanism already implemented or do I have to create my own persistence mechanism: e.g. serialize the column sets in a file on the disk?
Previous Topic:CCATS Numbers for Eclipse Platform
Next Topic:Mocking Workspace Objects
Current Time: Sun Jul 20 12:55:13 EDT 2025
Powered by FUDForum. Page generated in 0.24322 seconds
