Home » Eclipse Projects » Dali » Mapping file "META-INF/orm.xml" does not have ORM content
Mapping file "META-INF/orm.xml" does not have ORM content [message #517094] |
Fri, 26 February 2010 04:09  |
I am using orm.xml just for named query definitions, at least for the
moment. Everything works fine with Eclipselink JPA 2.0 at runtime, but
Dali always gives me this validation error:
I can see why it's doing this, as I indeed have no ORM content, but
technically, it's still a valid orm.xml file and works correctly at
runtime. Is this considered a bug in Dali?
Ari
Re: Mapping file "META-INF/orm.xml" does not have ORM content [message #517233 is a reply to message #517094] |
Fri, 26 February 2010 11:15   |
No, that file should be perfectly legal. The complaint is regarding whether or not Dali recognizes that file as being a legal orm.xml file.
Assuming you're using Dali 2.2 (and not a milestone), the problem may be that you're using a JPA 2.0 version of the orm.xml, which is not yet supported. If all you're doing is defining queries, a 1.0 version of the orm.xml should work just fine. Try that.
Otherwise, there could be a problem with Dali recognizing the file type, which should be solved with a project clean.
A third option is to try a milestone of Dali 2.3, which supports JPA 2.0 and EclipseLink 2.0 and also has solved some of these file content recognition issues. Being a milestone, it will have its stability problems compared to a release, but this might be tolerable in your situation.
- Paul
Re: Mapping file "META-INF/orm.xml" does not have ORM content [message #517367 is a reply to message #517233] |
Fri, 26 February 2010 23:32   |
Thanks, Paul.
Yep, I'm using Dali 2.2, Eclipse 3.5.1.
I was using the JPA 1.0 version of the orm.xml when I first encountered
the validation error. I just moved to 2.0, and it's still there.
Project clean seems to clear the error, that's correct. Whenever I
perform a JPA validation, though, the error comes up again.
> situation.
> - Paul
Thanks for the suggestion. It's not critical enough for me to switch to
a 2.3M, but good to know that 2.3 may address the problem.
Best,
Ari
Re: Mapping file "META-INF/orm.xml" does not have ORM content [message #618862 is a reply to message #517094] |
- Paul
Re: Mapping file "META-INF/orm.xml" does not have ORM content [message #618864 is a reply to message #618862] |
Sat, 27 February 2010 04:20  |
Thanks, Paul.
> situation.
> - Paul
Best,
Ari
Current Time: Sun Jul 20 12:52:35 EDT 2025
Powered by FUDForum. Page generated in 0.04725 seconds
