Xpand workflows and parameters [message #517086] |
Fri, 26 February 2010 03:24  |
I read that topic, and the MWE documentation
http://www.eclipse.org/forums/index.php?t=msg&th=161471& amp; amp;start=0&
Still, some things are not clear to me.
I see you can declare Properties, which references to a property file, or defines a simple property.
but can you modify the workflow to add parameters to it's execution ?
By parameters, I mean adding options to the generation, defining if you generate all your code in the same file, or change the generated packages name, how many of them there are, and so on.
thanks
[Updated on: Fri, 26 February 2010 03:27] by Moderator
Re: Xpand workflows and parameters [message #518107 is a reply to message #517086] |
Wed, 03 March 2010 00:35  |
> http://www.eclipse.org/forums/index.php?t=msg&th=161471& amp;start=0&
You can simply pass parameters to a workflow, which will override any
local properties.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
FUDForum. Page generated in 0.04246 seconds
