Home » Language IDEs » PHP Development Tools (PDT) » What am I doing wrong here
What am I doing wrong here [message #516920] Thu, 25 February 2010 09:05 Go to next message
Originally posted by: eclipse.iancoetzee.za.net
Hi all
It might just be something stupid that I am overlooking (or ignoring)
I have (for testing purposes) two php files, newfile.php and test.php
in newfile.php I have
> <?php
> class testing
> function test()
> return "1234";
and in test.php I have
> <?php
> require_once 'newfile.php';
> $test = testing::
on line 4 in test.php whenever I start typing "testing" I get a code
assist dialog which pops up and suggest the class "testing" as defined
in newfile.php. However when I press <enter> I expect it to pop up with
a code assist dialog which suggests function "test()". But it does not.
I have tried replacing "function test()" with "public function test()"
but that do not do the trick :(
This is a new PHP 5.3 project I created for the purpose of posting to
this newsgroup.
Thank you in advance
Ian
Re: What am I doing wrong here [message #517131 is a reply to message #516920] Fri, 26 February 2010 06:05 Go to previous messageGo to next message
Originally posted by: christian.wolf.sedo.de
Hi Ian,
since you are calling the function test() statically, you should also
declare it static:
newfile.php:
<?php
class testing
public static function test()
return "1234";
If you didn't want to call it statically, you should use something like:
test.php:
<?php
$obj = new testing();
$test = $obj->test();
In this case, code completion also works after typing "$obj->".
Christian A. Wolf
Re: What am I doing wrong here [message #517158 is a reply to message #517131] Fri, 26 February 2010 07:20 Go to previous message
On 2010/02/26 01:05 PM, Christian Alexander Wolf wrote:
> Hi Ian,
> declare it static:
> newfile.php:
> <?php
> class testing
> return "1234";
Adding that "static" worked like a charm, thank you very much
Ian
Previous Topic:Some Basic PDT Questions
Next Topic:Intermittent Loss of PHP Code Highlighting
Current Time: Sat Jul 19 19:58:25 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
