Home » Modeling » GMF (Graphical Modeling Framework) » [Teneo + GMF + EMF Validation] EMF validation set to console, still a dialog appears.
[Teneo + GMF + EMF Validation] EMF validation set to console, still a dialog appears. [message #516650] Wed, 24 February 2010 11:28 Go to next message
Hi there,
I have set a couple of audits on a diagram, which has a semantic model
persisted using Teneo. I have also included the EMF Validation Ui
plugin, which allows me to set the output to be console instead of a
dialog box.
Now when saving the diagram, my diagram gets validated and I still get a
dialog instead of console output when the constraint fails.
I also get the teneo exception:
org.eclipse.emf.teneo.StoreValidationException
However when I edit from the Properties View, I do get live validation
on the console.
So is this dialog from GMF or is it the Teneo exception, which forces
the UI to give the dialog? (I would suspect the latter).
Thanks Christophe
Re: [Teneo + GMF + EMF Validation] EMF validation set to console, still a dialog appears. [message #516850 is a reply to message #516650] Thu, 25 February 2010 06:20 Go to previous messageGo to next message
Hi Christophe,
I don't know the specifics of when a dialog or when validation is shown in the console. Assuming that the exception is
expected then I would say that it is not caught at the correct place and therefore forces a dialog. But again, I have
practically no knowledge of the program flow (and the validation ui) so I can't really comment...
If the exception itself is not correct (i.e. it should not happen) then I would need to get more details to comment
(what does it fail, what is that stacktrace, what is the message).
gr. Martin
Christophe Bouhier wrote:
> Hi there,
> dialog box.
> on the console.
> Thanks Christophe
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo + GMF + EMF Validation] EMF validation set to console, still a dialog appears. [message #516917 is a reply to message #516850] Thu, 25 February 2010 09:12 Go to previous message
Hi Martin,
See my comment below, and thank you for your swift response.
Martin Taal wrote:
> Hi Christophe,
> in the console. Assuming that the exception is expected then I would say
> dialog.
Excellent point, the exception is expected as it is a constraint I have
set on a model element. The issue might be that EMF life Validation is
actually not executed when saving the diagram (As it is normally forced
by the action Edit->Validation), but Teneo executes the validation and
throws the exception.
But again, I have practically no knowledge of the program flow
Same here :).
> I would need to get more details to comment (what does it fail, what is
It is correct, I would be nice to hear from the GMF experts what
validation cycle happens when saving a diagram.
Dank je!
Christophe
Previous Topic:Disable adviceBinding
Next Topic:Extending/Specializing
Current Time: Sun Jul 20 07:47:53 EDT 2025
Powered by FUDForum. Page generated in 0.03309 seconds
