Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] nested references in the model diff(How can we merge models when a attribute has nested references)
[EMF Compare] nested references in the model diff [message #516062] Mon, 22 February 2010 11:03 Go to next message
I am studying the EMF compare merger and I found a problem with the merge of reference.
I reproduced the problem with the inventory meta-model I got from the EMF CVS: org.eclipse.emf/org.eclipse.emf.cdo/examples/org.gastro.inve ntory/model/inventory.ecore it would be easier to describe.
In this meta-model you can find
* Section which has a attribute Offering with Containment = false => a reference
* Offering has a attribute product with Containment = false as well
In my right model I have got
Section:: Section1
-Offering:: offer1
-- Product:: product1
In my left model, If I add an offering :
Section: Section1
-Offering:: offer1
-Offering:: offer2
The diff model will detect an ModelElementChangeLeftTarget
<subDiffElements xsi:type="diff:DiffGroup">
       <subDiffElements xsi:type="diff:ModelElementChangeLeftTarget">
       <rightParent href="platform:/resource/Model%20Compare/cdo-compare/tocompare/resto1c.inventory#/0/@menuCards.0/@sections.0"/>
        <leftElement href="platform:/resource/Model%20Compare/cdo-compare/tocompare/resto1.inventory#/0/@menuCards.0/@sections.0/@offerings.1"/>
         </subDiffElements>
       </subDiffElements>
If I do a merge LeftToRigth, I will have the offer2 merged but not the its reference to product1:
Section: Section1
-Offering:: offer1
-Offering:: offer2
In this case a second compare with I want :
Section: Section1
-Offering:: offer1
-Offering:: offer2
will give us the updated reference:
<subDiffElements xsi:type="diff:UpdateReference">
      <reference href="http://www.gastro.org/inventory/1.0#//Offering/product"/>
          <rightElement href="platform:/resource/Model%20Compare/cdo-compare/tocompare/resto1c.inventory#/0/@menuCards.0/@sections.0/@offerings.1"/>
             <leftTarget href="platform:/resource/Model%20Compare/cdo-compare/tocompare/resto1.inventory#/0/@departments.0/@stocks.0/@products.0"/>
            <rightTarget href="platform:/resource/Model%20Compare/cdo-compare/tocompare/resto1c.inventory#/0/@departments.0/@stocks.0/@products.0"/>
  </subDiffElements>
  <rightParent href="platform:/resource/Model%20Compare/cdo-compare/tocompare/resto1c.inventory#/0/@menuCards.0/@sections.0/@offerings.1"/>
 </subDiffElements>
In summary, to be able to merge the addition of an Offering and a product, I needed to merge twice.
1. Is it normal that have to detect this change in 2 times ? Does it mean that the ModelElementChangeLeftTargetMerger does not care about the nested reference within the newly-added child ? (in this case product)
2. Does it mean that if I had n nested references, I would be able to merge by comparing and merging n times ?
3. Which method do you advise to merge nested references?
Thank you !
Sabri.
[Updated on: Mon, 22 February 2010 11:05] by Moderator
Re: [EMF Compare] nested in the model diff [message #516216 is a reply to message #516062] Tue, 23 February 2010 03:53 Go to previous message
--------------090501030004050601010607
Hi Sabri,
Please use the EMF newsgroup for any question related to EMF Compare.
The reference under the merged element should have been copied along ...
fot it not to be merged means we have a bug in the merger code. Please
raise a bug against EMF Compare for this issue.
Laurent Goubet
Obeo
Sabri Skhiri wrote:
> merge of reference.
> In this meta-model you can find * Section which has a attribute Offering
> Section:: Section1
> -Offering:: offer1
> Section: Section1
> -Offering:: offer1
> -Offering:: offer2
> <rightParent
> href=" platform:/resource/Model%20Compare/cdo-compare/tocompare/res to1c.inventory#/0/@menuCards.0/@sections.0 "/>
> <leftElement
> href=" platform:/resource/Model%20Compare/cdo-compare/tocompare/res to1.inventory#/0/@menuCards.0/@sections.0/@offerings.1 "/>
> </subDiffElements>
> <rightParent
> </subDiffElements>
> Section: Section1
> -Offering:: offer1
> -Offering:: offer2
> Section: Section1
> -Offering:: offer1
> -Offering:: offer2
> <reference
> <rightElement
> href=" platform:/resource/Model%20Compare/cdo-compare/tocompare/res to1c.inventory#/0/@menuCards.0/@sections.0/@offerings.1 "/>
> <leftElement
> <leftTarget
> href=" platform:/resource/Model%20Compare/cdo-compare/tocompare/res to1.inventory#/0/@departments.0/@stocks.0/@products.0 "/>
> <rightTarget
> href=" platform:/resource/Model%20Compare/cdo-compare/tocompare/res to1c.inventory#/0/@departments.0/@stocks.0/@products.0 "/>
> </subDiffElements>
> <rightParent
> </subDiffElements>
> <rightParent
> Thank you !
> Sabri.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------090501030004050601010607--
Previous Topic:[JS4EMF] Proposal feedback
Next Topic:[EMF Compare] nested in the model diff
Current Time: Sat Jul 19 16:53:37 EDT 2025
Powered by FUDForum. Page generated in 0.03664 seconds
