Home » Modeling » GMF (Graphical Modeling Framework) » GMF problem(error message)
GMF problem [message #516159] Mon, 22 February 2010 17:44 Go to next message
I am new to modeling, and recently started using GMF. After going through part 1 & 2 of the mindmap tutorial, i started a new project from scratch, but i ran into some problems. Basically, as far as i have gotten, i have 1 Eclass that i would like to generate for. When trying to generate a genmodel, i get these error messages of the type:
"Validation failed unexpectedly for", followed by the name of each of the elements in my mapping. The error messages in the log all says the same:
java.lang.ClassCastException: org.eclipse.gmf.gmfgraph.impl.NodeImpl cannot be cast to org.eclipse.gmf.gmfgraph.DiagramLabel
at org.eclipse.gmf.mappings.impl.LabelMappingImpl.getDiagramLab el(LabelMappingImpl.java:93)
at org.eclipse.gmf.mappings.impl.LabelMappingImpl.eGet(LabelMap pingImpl.java:207)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1013)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1005)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:409)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryPr oxyResolves(EObjectValidator.java:432)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDe faultConstraint(EObjectValidator.java:209)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:190)
at org.eclipse.gmf.internal.validate.ValidatorChain.validate(Va lidatorChain.java:67)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:164)
at org.eclipse.gmf.internal.bridge.transform.ValidationHelper$S martDiagnostician.validate(ValidationHelper.java:96)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:143)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:179)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:167)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:183)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:114)
at org.eclipse.gmf.internal.bridge.transform.ValidationHelper.v alidate(ValidationHelper.java:288)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lOperation.loadMappingModel(TransformToGenModelOperation.jav a:160)
at org.eclipse.gmf.internal.bridge.transform.MapModelConfigurat ionPage.doLoadResource(MapModelConfigurationPage.java:36)
at org.eclipse.gmf.internal.bridge.transform.ModelConfiguration Page$1.execute(ModelConfigurationPage.java:53)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:106)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:118)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 944)
at org.eclipse.gmf.internal.bridge.transform.ModelConfiguration Page.loadResource(ModelConfigurationPage.java:67)
at org.eclipse.gmf.internal.common.ui.ModelSelectionPage.update URI(ModelSelectionPage.java:290)
at org.eclipse.gmf.internal.common.ui.ModelSelectionPage.initCo ntrols(ModelSelectionPage.java:275)
at org.eclipse.gmf.internal.common.ui.ModelSelectionPage.setVis ible(ModelSelectionPage.java:382)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1171)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1149)
at org.eclipse.jface.wizard.WizardDialog$5.run(WizardDialog.jav a:1138)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1136)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:830)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lAction.run(TransformToGenModelAction.java:72)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Does anyone have an idea of what could cause this?
Cheers!
Re: GMF problem [message #516168 is a reply to message #516159] Mon, 22 February 2010 18:25 Go to previous messageGo to next message
Hi Torbj,
I am new to modeling too, but it seems that you might have Feature Label Mapping elements in your gmfgraph without the Diagram Label attribute set. If you create the gmfgraph by using the Wizard, they might not be set automatically. For more information, see the following tutorial:
http://www.javaexpress.pl/article/show/Graphical_Modelling_F ramework
I hope this helps.
Luis
Re: GMF problem [message #516243 is a reply to message #516159] Tue, 23 February 2010 05:47 Go to previous message
I started over a bit, to simplify even more..
Right now, my ecore model consists of an Eclass called Class, which is contained in a DocumentRoot Eclass. The tool palette is generated straight forward i guess.. The gmfgraph contains a figure descriptor ClassFigure, which contains a Rectangle ClassFigure, which again contains a label ClassNameFigure. I also have a child access getFigureClassNameFigure, which points to the ClassNameFigure label. The node class has figure descriptor ClassFigure as a figure, and diagram label ClassFigure has the child access mentioned as accessor, and figure descriptor ClassFigure as figure.
In mappings, i have a top node reference with containment feature DocumentRoot .classRoot:Class. I then have a node mapping, with domain meta information element Class, diagram node Node Class, and tool creation tool Class. With this, i can generate a generator model (although when running i can't actually draw anything ). But, when i try to add a label mapping (feature label or label), i get error messages like before (slight difference from before in the casting though):
java.lang.ClassCastException: org.eclipse.gmf.gmfgraph.impl.FigureDescriptorImpl cannot be cast to org.eclipse.gmf.gmfgraph.DiagramLabel
at org.eclipse.gmf.mappings.impl.FeatureLabelMappingImpl.eGet(F eatureLabelMappingImpl.java:337)
at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.handleC rossReference(EcoreUtil.java:1692)
at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.crossRe ference(EcoreUtil.java:1670)
at org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .findExternalCrossReferences(EcoreUtil.java:1906)
at org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .find(EcoreUtil.java:1918)
at org.eclipse.gmf.internal.validate.ExternModelImport.initiali zeExternPackages(ExternModelImport.java:142)
at org.eclipse.gmf.internal.validate.ExternModelImport.getImpor ter(ExternModelImport.java:99)
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator.hand leMetaModel(AnnotatedOclValidator.java:72)
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator.vali date(AnnotatedOclValidator.java:47)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Edit: Started over again, and now it works.. gotta love gmf error messages though Razz
[Updated on: Tue, 23 February 2010 08:20] by Moderator
Previous Topic:How to mark Nodes
Next Topic:PropertySheet/Common Navigator problem
Current Time: Sun Jul 20 10:15:14 EDT 2025
Powered by FUDForum. Page generated in 0.11935 seconds
