Home » Modeling » EMF » [CDO] custom EDataTypes
[CDO] custom EDataTypes [message #515302] Thu, 18 February 2010 07:46 Go to next message
Hi all,
our model contains a Polygon object which holds a list of Point objects, which are
custom EDataType.
When I make a copy of the Point list with
List<Point> points= new ArrayList<Point>(polygon.getPoints());
ArrayList calls the collection's toArray() method and EMF/CDO returns list of Strings instead of a list of Point objects.
The strings are the result of convertPointToString() serializer method.
This causes some problems, e.g. because EMF EDIT's RemoveCommand also uses ArrayList to create a copy of the to be removed objects.
Thanks in advance
Rolf
Re: [CDO] custom EDataTypes [message #515404 is a reply to message #515302] Thu, 18 February 2010 11:41 Go to previous messageGo to next message
Hi Rolf,
I think there's a bug in CDOStore's toArray() implementations. Please
file a bugzilla.
Cheers
/Eike
Am 18.02.2010 13:46, schrieb Rolf Kistler:
> Hi all,
> objects, which are
> custom EDataType.
> Thanks in advance
> Rolf
Re: [CDO] custom EDataTypes [message #515540 is a reply to message #515302] Fri, 19 February 2010 05:26 Go to previous messageGo to next message
I filed a bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303279
Rolf
Re: [CDO] custom EDataTypes [message #515561 is a reply to message #515540] Fri, 19 February 2010 05:57 Go to previous messageGo to next message
Am 19.02.2010 11:26, schrieb Rolf Kistler:
> I filed a bugzilla:
I fixed it ;-)
Cheers
/Eike
Re: [CDO] custom EDataTypes [message #515965 is a reply to message #515302] Mon, 22 February 2010 06:27 Go to previous messageGo to next message
I still have problems with custom EData Types when an EMF EDIT RemoveCommand
is invoked on a custom EDataType collection:
	at  org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.getList(BaseCDORevision.java:564)
	at  org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision.contains(BaseCDORevision.java:428)
	at  org.eclipse.emf.internal.cdo.CDOStore.contains(CDOStore.java :247)
	at  org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateContains(EStoreEObjectImpl.java:205)
	at  org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateContainsAll(EStoreEObjectImpl.java:213)
	at  org.eclipse.emf.common.util.DelegatingEList.containsAll(DelegatingEList.java:125)
	at  org.eclipse.emf.edit.command.RemoveCommand.prepare(RemoveCommand.java:248)
getList() returns list of Strings instead of list of custom EDataType, thus containsAll returns false and the objects are not removed.
I use CDO 3.0 HEAD (fix for https://bugs.eclipse.org/bugs/show_bug.cgi?id=303279 included)
Rolf
[Updated on: Mon, 22 February 2010 06:38] by Moderator
Re: [CDO] custom EDataTypes [message #516046 is a reply to message #515965] Mon, 22 February 2010 10:26 Go to previous messageGo to next message
Hi Rolf,
If you feel there's a bug somewhere in CDO, please just file a bugzilla.
You don't necessarily have to go through the newsgroup. I can not start
fixing something without a bugzilla.
Cheers
/Eike
Am 22.02.2010 12:27, schrieb Rolf Kistler:
> RemoveCommand
> :247)
> mand.java:248)
> Rolf
Re: [CDO] custom EDataTypes [message #516061 is a reply to message #515302] Mon, 22 February 2010 11:03 Go to previous message
I filed a bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303502
Rolf
Previous Topic:bidirectional cross references
Next Topic:Navigating on UML metamodel
Current Time: Sat Jul 19 07:06:19 EDT 2025
Powered by FUDForum. Page generated in 0.04286 seconds
