Home » Eclipse Projects » Rich Client Platform (RCP) » Adding a search box to main toolbar ?
Adding a search box to main toolbar ? [message #515892] Sun, 21 February 2010 21:02 Go to next message
In my application I want to have a search box in the main toolbar. I also
need a combo box added for user to specify the type of search. Is there a
way to do so ?
If yes how do I do it using pluggin. And how can I access the value returned
by the above input field. Please do let me know if anybody have any idea on
this.
Thanks in Advance!
Neha.
Re: Adding a search box to main toolbar ? [message #515901 is a reply to message #515892] Mon, 22 February 2010 02:54 Go to previous messageGo to next message
Look at:
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/reference/extension-points/org_eclipse_ui_menus.html
Especially: menuContribution's control contribution.
Re: Adding a search box to main toolbar ? [message #515918 is a reply to message #515892] Mon, 22 February 2010 03:55 Go to previous message
> way to do so ?
> this.
My approach is a little bit low-level, but it gives you full control
over window layout in your RCP application. See the screencast:
http://blog.jcake.com/2010/01/17/creating-custom-eclipse-rcp -window-layout/
An easier approach is to place you widgets using org.eclipse.ui.menus
extension point but you will have to stick to standard layout.
piotr maj
jcake software
Previous Topic:selection stores the last element when an exception occurs
Next Topic:project setup and layout questions
Current Time: Sat Jul 19 16:37:27 EDT 2025
Powered by FUDForum. Page generated in 0.03807 seconds
