Errors during source build [message #483341] |
Tue, 01 September 2009 04:56  |
Hello!
From time to time, I get strange and annoying errors during simply build
my project source.
First error is (info from Error Log view):
Message:
de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on: Archive
file is read-only!
Exception Stack Trace:
java.io.FileNotFoundException:
file is read-only!
at
de.schlichtherle.io.ArchiveController.createOutputStream(Arc hiveController.java:579)
at
de.schlichtherle.io.FileOutputStream.createOutputStream(File OutputStream.java:164)
at de.schlichtherle.io.FileOutputStream.<init>(FileOutputStream.java:124)
at
org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .createManifestFile(Unknown
Source)
at
org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .updatePackage(Unknown
Source)
at
org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .doBuild(Unknown
Source)
at
org.eclipse.mtj.internal.core.build.MTJIncrementalProjectBui lder.build(Unknown
Source)
at
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
at org.eclipse.core.internal.resources.Project$1.run(Project.ja va:522)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at
org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:502)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate$1.r un(LaunchConfigurationDelegate.java:423)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate.bui ldProjects(LaunchConfigurationDelegate.java:430)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate.bui ldForLaunch(LaunchConfigurationDelegate.java:126)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:821)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on:
Archive file is read-only!
at
de.schlichtherle.io.ArchiveFileSystem$LinkDelta.<init>(ArchiveFileSystem.java:487)
at
de.schlichtherle.io.ArchiveFileSystem$LinkDelta.<init>(ArchiveFileSystem.java:478)
at de.schlichtherle.io.ArchiveFileSystem.link(ArchiveFileSystem .java:469)
at de.schlichtherle.io.ArchiveFileSystem.link(ArchiveFileSystem .java:403)
at
de.schlichtherle.io.ArchiveController.createOutputStream0(Ar chiveController.java:620)
at
de.schlichtherle.io.ArchiveController.createOutputStream(Arc hiveController.java:570)
... 30 more
Session Data:
eclipse.buildId=I20090611-1540
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Framework arguments: -product org.eclipse.epp.package.java.product
-showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -product
org.eclipse.epp.package.java.product -showlocation -debug
And the second problem is:
Message:
D:\Work\PocketMSS\PocketMSS\.mtj.tmp\emulation\PocketMSS.jar (couldn't
preserve last modification time)
de.schlichtherle.io.ArchiveWarningException:
at
de.schlichtherle.io.UpdatingArchiveController.update(Updatin gArchiveController.java:907)
at
de.schlichtherle.io.UpdatingArchiveController.umount0(Updati ngArchiveController.java:697)
at
de.schlichtherle.io.UpdatingArchiveController.umount(Updatin gArchiveController.java:642)
at
de.schlichtherle.io.ArchiveControllers.umount(ArchiveControl lers.java:318)
at de.schlichtherle.io.File.umount(File.java:1099)
at
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Session Data:
-showlocation
If I Clean all project and Rebuild it this helps for some time.
My question is how can I avoid this errors at all?
Re: Errors during source build [message #580370 is a reply to message #580163] |
Fri, 14 May 2010 21:11  |
unfortunately the guy that implemented this part of the code is not an active commiter anymore, and since we work on MTJ in our spare time there not a lot of time left to understand / reproduce this issue and work on a fix. as member of this community i apologize for that.
i really hope that this was fixed before. i sent an email to MTJ developer list to see if anyone else is able to work on this fix .
PS.: generating a build is much easier since i did a good part of it :)
FUDForum. Page generated in 0.10227 seconds
