Home » Eclipse Projects » Remote Application Platform (RAP) » Tree-Widget in RAP
Tree-Widget in RAP [message #515393] Thu, 18 February 2010 11:24 Go to next message
I know you RAP guys have a lot to do and what you've done so far is really
impressive but anyhow I'd like to point out *gently* that the current
support for the Tree widget is ... hmm ... let's say rather poor:
For example:
- no tooltips
- SWT.FULL_SELECTION not working
- setLinesVisible() not working, though there is already a patch available
in Bug 232406 (but is somehow not considered)
- and not to forget about all those open bugs and enhancement requests
regarding this widget.
Do you think it is possible to revise it in "near" future?
The way the works right now, it is hardly usable...
Niels
Re: Tree-Widget in RAP [message #515444 is a reply to message #515393] Thu, 18 February 2010 13:55 Go to previous messageGo to next message
Niels,
I fully understand that you are unsatisfied with the current state of
the Tree widget. Though "hardly usable" depends on the use case. In
other cases than yours, it serves quite well. Anyway, I don't want to argue.
Apart from tooltips, the limitations are rooted in the client-side Tree
widget that comes from the qx library. The qx-Tree just wasn't made with
requirements in mind as they arise in the RAP/RCP environment it is
placed. We already pushed the Tree as far as we can get with reasonable
effort.
To get around these bugs it is required to re-implement the widget from
scratch (as done with the Table widget). And that isn't realistic for
the near future.
Rüdiger Herrmann
http://eclipsesource.com
> really impressive but anyhow I'd like to point out *gently* that the
> current support for the Tree widget is ... hmm ... let's say rather poor:
> For example:
> - no tooltips
> available in Bug 232406 (but is somehow not considered)
> Niels
Re: Tree-Widget in RAP [message #515518 is a reply to message #515444] Thu, 18 February 2010 22:08 Go to previous message
"Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
news:hlk2fq$rs3$1@build.eclipse.org...
> Niels,
> I fully understand that you are unsatisfied with the current state of the
> Tree widget. Though "hardly usable" depends on the use case. In other
You're right. In my case - showing two columns, make one editable - its
current state is not reasonable for
a user to work on it. If you have only one column it might be sufficient.
> effort.
> scratch (as done with the Table widget). And that isn't realistic for the
> near future.
This is at least good to know. I should use a table instead.
Niels
> Regards,
> Rüdiger Herrmann
>> For example:
>> - no tooltips
>> Thanks,
>> Niels
Previous Topic:Moveable Views/Editors
Next Topic:ProgressMonitor registration
Current Time: Sat Jul 19 14:34:14 EDT 2025
Powered by FUDForum. Page generated in 0.46587 seconds
