Home » Archived » Buckminster » Get Maven component from SVN
Get Maven component from SVN [message #514955] Wed, 17 February 2010 05:33 Go to next message
is it possible to get a maven component type from within a svn provider?
If i configure my rmap to use a svn provider, buckminster will reject it - because no version matches.
When i checkout the maven project manually and look up his cspec i couldn't see a version in the editor either.
(I've created a simple maven project 'maven-archetype-quickstart'. And checked the behaviour with Buckminster 3.5 and 3.6.
On debugging the MavenCSpecBuilder it seems like that no version is read from the pom.xml)
Thanks for the advise.
Regards Matthias
Re: Get Maven component from SVN [message #514991 is a reply to message #514955] Wed, 17 February 2010 07:56 Go to previous messageGo to next message
Maybe i should attach some Buckminster files:
CQuery:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="file:/C:\ws\my.rmap">
    <cq:rootRequest name="component.a" componentType="maven" versionDesignator="raw:[0.0.1.M,0.0.1.M]/format(n[.n=0;[.n=0;]][d?S=M;]):0.0.1,0.0.1"/>
    <cq:advisorNode namePattern="component\.a" componentType="maven" mutableLevel="REQUIRE" sourceLevel="REQUIRE"/>
</cq:componentQuery>
RMap:
<rm:rmap xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns:maven="http://www.eclipse.org/buckminster/MavenProvider-1.0" xmlns:rm="http://www.eclipse.org/buckminster/RMap-1.0">
  <rm:locator pattern="^component\.a" searchPathRef="sp"/>
  <rm:locator searchPathRef="mavenRepo"/>
  <rm:searchPath name="sp">
    <rm:provider componentTypes="maven" readerType="svn">
      <rm:uri format="http://svn/trunk/test/{0}">
        <bc:propertyRef key="buckminster.component"/>
      </rm:uri>
    </rm:provider>
  </rm:searchPath>
  <rm:searchPath name="mavenRepo">
    <rm:provider xsi:type="maven:MavenProvider" componentTypes="maven" readerType="maven2" source="false" mutable="false">
      <rm:uri format="http://localhost:8081/nexus/content/groups/public-snapshots"/>
    </rm:provider>
      <rm:uri format="http://localhost:8081/nexus/content/groups/public"/>
    </rm:provider>
  </rm:searchPath>
</rm:rmap>
With the attribute 'versionDesignator' the provider will be rejected Crying or Very Sad . Without the 'versionDesignator' it will work.
[Updated on: Wed, 17 February 2010 07:57] by Moderator
Re: Get Maven component from SVN [message #515144 is a reply to message #514991] Wed, 17 February 2010 16:10 Go to previous messageGo to next message
Hi Matthias,
Is your objective to obtain a maven component as source from SVN or do you have a repository of binaries checked in?
Will you always access the trunk or are you planning to use branches for the checkouts?
Thomas Hallgren
> CQuery:
> <cq:componentQuery
> versionDesignator=" raw:[0.0.1.M,0.0.1.M]/format(n[.n=0;[.n=0;]][d?S=M;]):0.0.1, 0.0.1 "/>
> RMap:
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> <rm:uri
> </rm:provider>
> </rm:provider>
> </rm:searchPath>
> </rm:rmap>
> :cry: . Without the 'versionDesignator' it will work.
> [/CODE]
Re: Get Maven component from SVN [message #515152 is a reply to message #515144] Wed, 17 February 2010 16:34 Go to previous messageGo to next message
> Hi Matthias,
Hi Thomas,
I want to get a maven component as source from SVN.
> the checkouts?
For test purposes i will only use the trunk. But you're right, it must
be possible to checkout from branches in future.
> Regards,
> Thomas Hallgren
Regards - Matthias
>> CQuery:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cq:componentQuery
>> RMap:
>> </rm:uri>
>> </rm:provider>
>> </rm:searchPath>
>> <rm:uri
>> </rm:provider>
>> </rm:provider>
>> </rm:searchPath>
>> </rm:rmap>
>> [/CODE]
Re: Get Maven component from SVN [message #515159 is a reply to message #514991] Wed, 17 February 2010 17:20 Go to previous messageGo to next message
Hi Matthias,
Can you please enter a bugzilla for this (Tools/Buckminster/providers). A log using DEBUG output when the
versionDesignator is in effect might be helpful.
Thomas Hallgren
> CQuery:
> <cq:componentQuery
> RMap:
> </rm:uri>
> </rm:provider>
> </rm:searchPath>
> <rm:uri
> </rm:provider>
> </rm:provider>
> </rm:searchPath>
> </rm:rmap>
> [/CODE]
Re: Get Maven component from SVN [message #515305 is a reply to message #515159] Thu, 18 February 2010 08:00 Go to previous message
Hi Thomas,
I have filed a Bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=303172)
regards - matthias
Previous Topic:RMap redirect breaks searchPath overlap
Next Topic:Is there an error in the Buckybook or in Buckminster?
Current Time: Sat Jul 19 22:43:43 EDT 2025
Powered by FUDForum. Page generated in 0.04447 seconds
