Home » Modeling » TMF (Xtext) » Does xbase work?
Does xbase work? [message #514799] |
Tue, 16 February 2010 06:50  |
I found xbase in the cvs repository.
I wonder if that is a good example or if it is just
dead code. There is a file called
org.eclipse.xtext.xbase/src/org/eclipse/xtext/xbase/example. xbase_example
which has some errors in the xbase editor.
What's going wrong here?
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Does xbase work? [message #649279 is a reply to message #514799] |
Tue, 18 January 2011 09:46   |
I m trying to get Xbase running by checking out xtext.xbase and xtext.common.types form the cvs repository. But if i run the xbase mw2, i get rule errors ...
7689 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for org.eclipse.xtext.xbase.Xpression with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, ParseTreeConstructorFragment, XtextAntlrGeneratorFragment, JavaBasedContentAssistFragment
error(211): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:92:1: [fatal] rule ruleXExpression has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2,6. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
warning(200): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:92:1: Decision can match input such as "'('" using multiple alternatives: 1, 2, 6
As a result, alternative(s) 2,6 were disabled for that input
warning(200): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:1864:2: Decision can match input such as "'else'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
error(211): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:3025:1: [fatal] rule ruleXExpressionInRichString has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2,5. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
warning(200): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:3025:1: Decision can match input such as "'('" using multiple alternatives: 1, 2, 5
As a result, alternative(s) 2,5 were disabled for that input
How did you get the editor running? Can you give me a hint?
Best,
Dan
Re: Does xbase work? [message #649424 is a reply to message #649279] |
Wed, 19 January 2011 03:19  |
Hi Dan,
are you sure that your meant the CVS repo? It's frozen since June 2010
because we migrated to git.
Please note that Xbase is still subject to change and clients should
currently use only with a good connection to the developers of Xtext ;-)
Sebastian
Am 18.01.11 15:46, schrieb Daniel S:
> error(211):
> ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/p arser/antlr/internal/InternalXpression.g:92:1:
> warning(200):
> warning(200):
> ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/p arser/antlr/internal/InternalXpression.g:1864:2:
> error(211):
> ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/p arser/antlr/internal/InternalXpression.g:3025:1:
> option.
> warning(200):
> Best,
> Dan
Current Time: Sat Jul 19 18:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.07669 seconds
