Home » Eclipse Projects » Eclipse Platform » Perfomance Monitoring - Fingerprint(Howto accumulate data shown at Eclipse)
Perfomance Monitoring - Fingerprint [message #513863] Thu, 11 February 2010 09:28 Go to next message
We have developed an Eclipsed based IDE, and what we need is a reliable way to provide performance monitoring fingerprints.
The following is a great example of what we like, used by Eclipse team: http://download.eclipse.org/eclipse/downloads/drops/R-3.5.1- 200909170800/performance/performance.php
The idea is simple: as part of our build process, a use case must be executed like "Open a file in an editor, change some of its properties, save the file into the workspace, and validate the file". Metrics must be accumulated and published. Just in a similar way as the Eclipse team does.
Does anyone know how this is done ? Which tools are used by Eclipse team to execute a test, accumulate the data, and store the results on a web page like the llink above ?
Thanks in advance,
Ad
[Updated on: Thu, 11 February 2010 10:05] by Moderator
Re: Perfomance Monitoring - Fingerprint [message #514731 is a reply to message #513863] Tue, 16 February 2010 08:50 Go to previous message
The answer is here:
http://wiki.eclipse.org/index.php/Platform-releng-faq
26 How do I set up performance tests?
27 How do I find data for old performance results on existing build page?
28 How do I run the performance tests from the zips provided on the download page?
29 Process to implement a new baseline
30 How to regenerate performance results from build artifacts
A must see:
http://www.eclipsecon.org/2005/presentations/EclipseCon2005_ 13.2ContinuousPerformance.pdf
Thanks to Frederic Fusier.
[Updated on: Tue, 16 February 2010 10:12] by Moderator
Previous Topic:Target Definition problems with Helios
Next Topic:Problems with Extending Ant Build Run with Ant tasks extensions
Current Time: Sat Jul 19 09:49:54 EDT 2025
Powered by FUDForum. Page generated in 0.03347 seconds
