Home » Archived » Buckminster » Materializing OSGI Bundle from Maven Repo into p2 site?!
Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514248] Fri, 12 February 2010 19:32 Go to next message
Hi folks,
I'm trying to get an RCP build working with the Hudson/Buckminster combo.
The problem I have is that the feature is referencing third party OSGi libs that are only found in the Ibiblio Maven repo.
Importing the feature then results in:
ERROR   [0002] : No repository found at http://www.ibiblio.org/maven2.
ERROR: No repository found at http://www.ibiblio.org/maven2.
ERROR: Errors and Warnings
org.eclipse.core.runtime.CoreException: Errors and Warnings
	at org.eclipse.buckminster.runtime.BuckminsterException.wrap(BuckminsterException.java:109)
	at org.eclipse.buckminster.core.materializer.MaterializationJob.internalRun(MaterializationJob.java:175)
	at org.eclipse.buckminster.core.materializer.MaterializationJob.run(MaterializationJob.java:144)
Contains: [0002] : No repository found at http://www.ibiblio.org/maven2.
INFO:  TAG-ID 0002 = Query for ...
I can work around this issue by adding an
mspecNode for the bundles in question that sets the materializer to filesystem; given the right installLocation I can even make them show up in the plugins directory of the site... but they are nested in some crazy maven folder structure ({$targetPlatform}/plugins/maven2/commons-io/...).
Whats the best way to resolve maven bundles into a p2 site?
Thanks in advance,
Phil
For your reference:
<mspec xmlns="http://www.eclipse.org/buckminster/MetaData-1.0"
	name="Target Platform MSPEC" materializer="p2" installLocation="${targetPlatformPath}"
	url="xxx.cquery">
	<property key="target.arch" value="*" />
	<property key="target.os" value="*" />
	<property key="target.ws" value="*" />
	<mspecNode namePattern="org\.apache\.lucene" exclude="true" />
	<mspecNode namePattern="xxx\..*" exclude="true" />
	<mspecNode namePattern="slf4j\..*" materializer="filesystem"
		installLocation="${targetPlatformPath}/plugins" />
	<mspecNode namePattern="org\.apache\.commons\.io"
		materializer="filesystem" installLocation="${targetPlatformPath}/plugins" />
</mspec>
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
	resourceMap="xxx_hudson.rmap">
	<cq:rootRequest name="xxx.product.feature" componentType="eclipse.feature" />
	<cq:advisorNode namePattern=".*" useTargetPlatform="false"
		useWorkspace="false" />
	<cq:property key="target.arch" value="*" />
	<cq:property key="target.os" value="*" />
	<cq:property key="target.ws" value="*" />
</cq:componentQuery>
<rmap xmlns="http://www.eclipse.org/buckminster/RMap-1.0"
	xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:mp="http://www.eclipse.org/buckminster/MavenProvider-1.0"
	xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0">
	<property key="base.path" value="D:/Workspace/Spielwiese" />
	<searchPath name="xxx">
		<provider readerType="local"
			componentTypes="osgi.bundle,eclipse.feature" mutable="true"
			source="true">
			<uri format="file:/{0}/{1}/">
				<bc:propertyRef key="base.path" />
				<bc:propertyRef key="buckminster.component" />
			</uri>
		</provider>
	</searchPath>
	<searchPath name="galileo">
		<provider readerType="eclipse.import" componentTypes="osgi.bundle,eclipse.feature"
			mutable="false" source="false">
			<uri format="http://download.eclipse.org/releases/galileo?importType=binary" />
		</provider>
	</searchPath>
	<searchPath name="maven">
		<provider xsi:type="mp:MavenProvider" readerType="maven2"
			componentTypes="osgi.bundle" mutable="false" source="false">
			<uri format="http://mirrors.ibiblio.org/pub/mirrors/maven2" />
			<mp:mappings>
				<mp:entry name="slf4j.api" groupId="org.slf4j" artifactId="slf4j-api" />
				<mp:entry name="slf4j.simple" groupId="org.slf4j"
					artifactId="slf4j-simple" />
				<mp:entry name="org.apache.commons.io" groupId="commons-io"
					artifactId="commons-io" />
			</mp:mappings>
		</provider>
	</searchPath>
	<locator searchPathRef="xxx" failOnError="false" />
	<locator searchPathRef="galileo" failOnError="false" />
	<locator searchPathRef="maven" />
</rmap>
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514250 is a reply to message #514248] Fri, 12 February 2010 19:45 Go to previous messageGo to next message
Hi Philippe,
What version of Buckminster are you using? If you are using 3.5, could you give 3.6 a try and see if you still have the
same problem?
You might want to consider using the Orbit p2 repository at Eclipse.org instead of Maven:
http://download.eclipse.org/tools/orbit/downloads/drops/R201 00114021427/
The p2 update site URL is:
http://download.eclipse.org/tools/orbit/downloads/drops/R201 00114021427/updateSite
HTH,
- thomas
On 02/13/2010 01:32 AM, Philipp Nanz wrote:
> Hi folks,
> at
> org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:109)
> at
> org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:175)
> at
> org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:144)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> I can work around this issue by adding an mspecNode for the bundles in
> Thanks in advance,
> Phil
> For your reference:
> url="xxx.cquery">
> </mspec>
> source="true">
> </uri>
> </provider>
> </searchPath>
> <uri
> format=" http://download.eclipse.org/releases/galileo?importType=bina ry" />
> </provider>
> </searchPath>
> <mp:mappings>
> </mp:mappings>
> </provider>
> </searchPath>
> </rmap>
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514263 is a reply to message #514250] Sat, 13 February 2010 04:03 Go to previous messageGo to next message
Hi Thomas,
thanks for the quick reply.
I have given it a try with 3.6 (freshly installed a few minutes ago via director), unfortunately that results in another error:
D:\p2\buckminster-3.6>java -Dbuckminster.output.root=/D:/hudson/jobs/TargetPlatf
orm/workspace//buckminster.output -Dbuckminster.temp.root=/D:/hudson/jobs/Target
Platform/workspace//buckminster.temp -DtargetPlatformPath=/D:/hudson/jobs/Target
Platform/workspace//targetPlatform -jar plugins/org.eclipse.equinox.launcher_1.1
.0.v20100208.jar -application org.eclipse.buckminster.cmdline.headless -data /D:
/hudson/jobs/TargetPlatform/workspace/ --loglevel info -S D:\hudson\jobs\TargetP
latform\builds\2010-02-13_09-42-59/commands.txt
INFO:  import 'file:/D:/target-platform.mspec'
WARN:  Use of deprecated value for attribute <provider readerType>. Was 'eclipse
.import', should be 'p2' : file:/D:/xxx_hudson.rmap, line 23.
ERROR   [0001] : java.lang.NoSuchMethodError: org.eclipse.buckminster.core.resol
ver.NodeQuery.getRevision()J
INFO:  TAG-ID 0001 = Query for xxx.product.feature:eclipse.feature
I have tried running it with debug, but even then I get no stacktrace. So I have no idea where this thing is coming from :-/
but then again even if it would work, it wouldn't really be an option for me though because the hudson-buckminster plugin doesn't support 3.6 yet.
As for Orbit, one of the wanted bundles isn't listed there Sad
Thanks for your time,
Phil
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514265 is a reply to message #514263] Sat, 13 February 2010 04:21 Go to previous messageGo to next message
Back on 3.5, I have tried another approach using ANT GET maps, but this time I get no component match found for the bundles in question.
ANT GET MAP
plugin@org.apache.commons.io,1.4.0=GET,http://mirrors.ibiblio.org/pub/mirrors/maven2/commons-io/commons-io/1.4/commons-io-1.4.jar
plugin@slf4j.api,1.5.10=GET,http://mirrors.ibiblio.org/pub/mirrors/maven2/org/slf4j/slf4j-api/1.5.10/slf4j-api-1.5.10.jar
plugin@slf4j.simple,1.5.10=GET,http://mirrors.ibiblio.org/pub/mirrors/maven2/org/slf4j/slf4j-simple/1.5.10/slf4j-simple-1.5.10.jar
New RMAP
	<property key="svn.user" value="philipp" />
	<property key="svn.pass" value="..." />
		<provider readerType="svn"
			source="true">
			<uri format="svn://{0}:{1}@htpc/xxx/trunk/{2}/">
				<bc:propertyRef key="svn.user" />
				<bc:propertyRef key="svn.pass" />
			</uri>
		</provider>
	</searchPath>
		</provider>
	</searchPath>
		<provider readerType="eclipse.import" componentTypes="osgi.bundle"
			<uri format="file:/D:/supplemental-plugins.map" />
		</provider>
	</searchPath>
	<locator searchPathRef="maven"/>
</rmap>
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514269 is a reply to message #514263] Sat, 13 February 2010 05:03 Go to previous messageGo to next message
Hi Philipp,
You're experiencing an incompatibility issue. Probably a mix between 3.5 and 3.6 bundles. Are you using Subversion from
our External site? If so, please read my latest posting "Reorganization of our external sites."
Thomas Hallgren
On 02/13/2010 10:03 AM, Philipp Nanz wrote:
> Hi Thomas,
> -data /D:
> 'eclipse
> yet.
> As for Orbit, one of the wanted bundles isn't listed there :(
> Phil
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514272 is a reply to message #514269] Sat, 13 February 2010 06:36 Go to previous messageGo to next message
ok, 3.6 up and running now (thanks!) but the error is now the same as on 3.5:
D:\hudson\jobs\TargetPlatform\workspace>exit 0
Commandline:
java -Dbuckminster.output.root=/D:/hudson/jobs/TargetPlatform/workspace//buckminster.output -Dbuckminster.temp.root=/D:/hudson/jobs/TargetPlatform/workspace//buckminster.temp -DtargetPlatformPath=/D:/hudson/jobs/TargetPlatform/workspace//targetPlatform -jar plugins/org.eclipse.equinox.launcher_1.1.0.v20100208.jar -application org.eclipse.buckminster.cmdline.headless -data /D:/hudson/jobs/TargetPlatform/workspace/ --loglevel info -S D:\hudson\jobs\TargetPlatform\builds\2010-02-13_12-32-31/commands.txt INFO:  import 'file:/D:/target-platform.mspec'
WARN:  Use of deprecated value for attribute <provider readerType>. Was 'eclipse.import', should be 'p2' : file:/D:/xxx_hudson.rmap, line 23.
	at org.eclipse.buckminster.runtime.BuckminsterException.wrap(BuckminsterException.java:96)
	at org.eclipse.buckminster.core.materializer.MaterializationJob.internalRun(MaterializationJob.java:150)
	at org.eclipse.buckminster.core.materializer.MaterializationJob.run(MaterializationJob.java:126)
INFO:  TAG-ID 0002 = Query for xxx.product.feature:eclipse.feature, path: xxx.product.feature:eclipse.feature$1.0.0.qualifier
Archiviere Artefakte
Finished: FAILURE
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514461 is a reply to message #514272] Mon, 15 February 2010 08:10 Go to previous messageGo to next message
Hi Philipp,
Can you please enter a bugzilla for this? If you attach a project with the sample mspec/cquery/rmap that would be very
helpful.
Thomas Hallgren
> 3.5:
> Commandline:
> java
> -Dbuckminster.output.root=/D:/hudson/jobs/TargetPlatform/wor kspace//buckminster.output
> -Dbuckminster.temp.root=/D:/hudson/jobs/TargetPlatform/works pace//buckminster.temp
> -DtargetPlatformPath=/D:/hudson/jobs/TargetPlatform/workspac e//targetPlatform
> D:\hudson\jobs\TargetPlatform\builds\2010-02-13_12-32-31/com mands.txt
> at
> org.eclipse.buckminster.runtime.BuckminsterException.wrap(Bu ckminsterException.java:96)
> at
> org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:150)
> at
> org.eclipse.buckminster.core.materializer.MaterializationJob .run(MaterializationJob.java:126)
> Finished: FAILURE
Re: Materializing OSGI Bundle from Maven Repo into p2 site?! [message #514678 is a reply to message #514461] Tue, 16 February 2010 05:29 Go to previous message
Hi Thomas,
thanks for your time! Bug has been added: https://bugs.eclipse.org/bugs/show_bug.cgi?id=302929
Kind Regards,
Philipp
Previous Topic:[Aggregator] Installation Problem
Next Topic:Turn root feature into p2 IU
Current Time: Sat Jul 19 16:51:00 EDT 2025
Powered by FUDForum. Page generated in 0.05363 seconds
